Generate Attributes
Lin_0420
I want to use the Generate Attributes to generate an attribute that can be added with one when it see true, and added 0 when it see false. Finally, the output is the total number. However, I do not know define it correctly.꒦ິ^꒦ິ
Please help me,thanks
BalazsBaranyRM
Hi!
How are your data structured? Do you have different attributes with true/false and you're interested in the number of true values in that row?
This could be solved with converting true/false to 1/0 (Map operator), parsing these numbers (Parse Numbers) and summing up the values (Generate Aggregation).
Balázs
BalazsBaranyRM
Hi!
Balázs
Lin_0420
Thank you!!!
@BalazsBarany
.You're so cool.But I don't quite understand what the principle is. Can you tell me?Could you please say something? Even if only a little ୧⍢⃝୨
BalazsBaranyRM
Hi!
Map takes values and changes them into other values. You could change male to m, female to f, or true to 1 and false to 0, whatever you need.
Parse Numbers does exactly what it says: It converts nominal (text) attributes that contain numbers into numeric attributes.
Generate Aggregation is very powerful. It can calculate sum, average, minimum and so on for every row of the input. Contrast this with the Aggregate operator which groups
rows
together to calculate the result. Generate Aggregation works on the
columns
of each row and just adds a new attribute.
Balázs
Lin_0420
Thank you very much!👍👍👍
@BalazsBarany
