Why do I get "SEVERE: Process failed: Your license only permits up to 0 rows of data in a process"
New Altair Community Member
Updated by Jocelyn
I'm testing out running a simple rapidminer process in the background using command line with rapidminer-batch.bat from scripts.
The rapidminer process just simply involve generating random data table and storing this data table (csv) in a local directory.
When I run:
"D:\Program Files\RapidMiner\scripts\rapidminer-batch.bat" -f "D:\Rapidminer Local Repository\Processes\Test Command Line.rmp"
I get the following:
I thought the free license can process 10000 rows.
When I run:
RAPIDMINER_HOME environment variable is not set. Trying the directory 'D:\Program Files\RapidMiner'...
Using local jre:
\Program Files\RapidMiner\jre\bin\java.exe...
The system cannot find the path specified.
Java Version: 1.8.0_265
Gathering launch settings...
Done.
Launching RapidMiner Studio BATCH now...
Oct 05, 2021 6:27:36 PM com.rapidminer.tools.PlatformUtilities logInfo
INFO: Searching in Java classpath for RapidMiner Studio jars...
INFO: Trying parent directory of 'D:\Program Files\RapidMiner\lib\rapidminer-studio-core-9.10.0.jar'...
INFO: Gotcha! 'rapidminer.home' is:
INFO: Release platform: WIN64
RapidMiner Studio version 9.10.000, Copyright (C) 2001-2021 RapidMiner GmbH
See End User License Agreement information in the file named EULA.
Oct 05, 2021 6:27:38 PM com.rapidminer.tools.PlatformUtilities logInfo
INFO: rapidminer.home is 'D:\Program Files\RapidMiner'.
Oct 05, 2021 6:27:40 PM com.rapidminer.core.license.ProductConstraintManager initialize
INFO: Initializing license manager.
INFO: Using default license location.
INFO: Registering default product.
Oct 05, 2021 6:27:42 PM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: Cloud Connectivity
INFO: Register plugin: Data Editor
INFO: Register plugin: H2O
INFO: Register plugin: Model Deployment Management
INFO: Register plugin: Model Simulator
INFO: Register plugin: Operator Recommender
INFO: Register plugin: Process Scheduling
INFO: Register plugin: Advanced File Connectors
INFO: Register plugin: Blending
INFO: Register plugin: Browser
INFO: Register plugin: Concurrency
INFO: Register plugin: CTA
INFO: Register plugin: HTML5 Charts
INFO: Register plugin: JDBC Connectors
INFO: Register plugin: Legacy Result Access
INFO: Register plugin: Productivity
INFO: Register plugin: Professional
INFO: Register plugin: Remote Repository
INFO: Register plugin: Utility
INFO: Register plugin: Social Media
INFO: Register plugin: Time Series
Oct 05, 2021 6:27:44 PM com.rapidminer.tools.config.ConfigurationManager register
INFO: Registered configurator Twitter Connection.
Oct 05, 2021 6:27:45 PM com.rapidminer.tools.config.ConfigurationManager register
INFO: Registered configurator Salesforce Connection.
INFO: Registered configurator Amazon S3 Connection.
INFO: Registered configurator Azure Blob Storage Connection.
INFO: Registered configurator Azure Data Lake Storage Gen1 Connection.
INFO: Registered configurator gui.configurable.cloud.azure.gen2.name.
INFO: Registered configurator Google Cloud Storage Connection.
INFO: Registered configurator Dropbox Connection.
Oct 05, 2021 6:27:48 PM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
WARNING: Missing database driver class name for Ingres
Oct 05, 2021 6:27:50 PM com.rapidminer.repository.RepositoryManager registerExtensionSamples
INFO: Registered 'Time Series' as sample folder.
Oct 05, 2021 6:27:51 PM com.rapidminer.tools.plugin.Plugin initAll
INFO: Extension Process Scheduling 9.7.0 was loaded in 165ms.
INFO: Extension Professional 9.10.0 was loaded in 189ms.
INFO: Extension Utility 9.10.0 was loaded in 197ms.
INFO: Extension Operator Recommender 9.7.0 was loaded in 213ms.
INFO: Extension Productivity 9.10.0 was loaded in 215ms.
INFO: Extension Concurrency 9.10.0 was loaded in 218ms.
INFO: Extension CTA 9.10.0 was loaded in 224ms.
INFO: Extension Legacy Result Access 9.10.0 was loaded in 227ms.
INFO: Extension Model Deployment Management 9.9.0 was loaded in 234ms.
INFO: Extension Blending 9.10.0 was loaded in 274ms.
INFO: Extension Model Simulator 9.10.0 was loaded in 300ms.
INFO: Extension Remote Repository 9.10.0 was loaded in 306ms.
INFO: Extension Social Media 9.6.0 was loaded in 355ms.
INFO: Extension Advanced File Connectors 9.10.0 was loaded in 368ms.
INFO: Extension Time Series 9.10.0 was loaded in 378ms.
INFO: Extension Data Editor 9.9.0 was loaded in 379ms.
INFO: Extension Browser 9.10.0 was loaded in 380ms.
INFO: Extension HTML5 Charts 9.10.0 was loaded in 474ms.
INFO: Extension H2O 9.9.0 was loaded in 545ms.
INFO: Extension Cloud Connectivity 9.10.0 was loaded in 881ms.
INFO: Extension JDBC Connectors 9.10.0 was loaded in 1628ms.
Oct 05, 2021 6:28:25 PM com.rapidminer.tools.config.ClientConfigurationManager loadAllParameters
INFO: No configuration file found for Amazon S3 Connection
INFO: No configuration file found for Azure Blob Storage Connection
INFO: No configuration file found for Azure Data Lake Storage Gen1 Connection
INFO: No configuration file found for gui.configurable.cloud.azure.gen2.name
INFO: No configuration file found for Dropbox Connection
INFO: No configuration file found for Salesforce Connection
INFO: No configuration file found for Google Cloud Storage Connection
INFO: No configuration file found for Twitter Connection
Oct 05, 2021 6:28:26 PM com.rapidminer.tools.ResultService init
INFO: No filename given for result file, using stdout for logging results!
Oct 05, 2021 6:28:26 PM com.rapidminer.Process execute
INFO: Process
\Rapidminer Local Repository\Processes\Test Command Line.rmp starts
Oct 05, 2021 6:28:26 PM com.rapidminer.launcher.CommandLineLauncher runProcessAndQuit
SEVERE: Process failed: Your license only permits up to 0 rows of data in a process, however the input data contained 10 rows.
com.rapidminer.operator.PortUserError: Your license only permits up to 0 rows of data in a process, however the input data contained 10 rows.
at com.rapidminer.extension.professional.operator.license.DataRowLimitCheck.showDataRowLimitExceededErrorOnce(DataRowLimitCheck.java:321)
at com.rapidminer.extension.professional.operator.license.DataRowLimitCheck.preOperator(DataRowLimitCheck.java:176)
at com.rapidminer.Process.fireProcessFlowBeforeOperator(Process.java:858)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:73)
at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:805)
at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:800)
at java.security.AccessController.doPrivileged(Native Method)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:800)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
at com.rapidminer.operator.Operator.execute(Operator.java:1023)
at com.rapidminer.Process.executeRoot(Process.java:1464)
at com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1443)
at com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:362)
at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:175)
SEVERE: Here: Process[1] (Process)
subprocess 'Main Process'
==> +- Generate Data[1] (Generate Data)
+- Write CSV[0] (Write CSV)
SEVERE: Process not successful
1 - 1 of
11
Make sure that you at least started the UI mode once and accepted the EULA etc.
Greetings,
Jonas
