<?xml version="1.0" encoding="UTF-8"?><process version="7.6.003"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="7.6.003" expanded="true" name="Process"><br> <process expanded="true"><br> <operator activated="true" class="concurrency:loop_files" compatibility="7.6.003" expanded="true" height="82" name="Loop Files" width="90" x="313" y="34"><br> <parameter key="directory" value="C:\Users\r\P4_XML_TCP\test"/><br> <parameter key="filter_by_glob" value="*.txt"/><br> <parameter key="enable_macros" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="text:read_document" compatibility="7.5.000" expanded="true" height="68" name="Read Document" width="90" x="112" y="136"/><br> <operator activated="true" class="multiply" compatibility="7.6.003" expanded="true" height="103" name="Multiply" width="90" x="246" y="136"/><br> <operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize" width="90" x="380" y="238"/><br> <operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases" width="90" x="514" y="238"/><br> <operator activated="true" class="text:documents_to_data" compatibility="7.5.000" expanded="true" height="82" name="Documents to Data" width="90" x="380" y="34"><br> <parameter key="text_attribute" value="file_name"/><br> <parameter key="label_attribute" value="file_name"/><br> </operator><br> <operator activated="true" class="extract_macro" compatibility="7.6.003" expanded="true" height="68" name="Extract Macro" width="90" x="514" y="34"><br> <parameter key="macro" value="file_name"/><br> <list key="additional_macros"/><br> </operator><br> <connect from_port="file object" to_op="Read Document" to_port="file"/><br> <connect from_op="Read Document" from_port="output" to_op="Multiply" to_port="input"/><br> <connect from_op="Multiply" from_port="output 1" to_op="Documents to Data" to_port="documents 1"/><br> <connect from_op="Multiply" from_port="output 2" to_op="Tokenize" to_port="document"/><br> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/><br> <connect from_op="Transform Cases" from_port="document" to_port="output 1"/><br> <connect from_op="Documents to Data" from_port="example set" to_op="Extract Macro" to_port="example set"/><br> <portSpacing port="source_file object" spacing="0"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> <portSpacing port="sink_output 2" spacing="0"/><br> </process><br> </operator><br> <operator activated="true" class="loop_collection" compatibility="7.6.003" expanded="true" height="103" name="Loop Collection" width="90" x="447" y="34"><br> <parameter key="unfold" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="text:write_document" compatibility="7.5.000" expanded="true" height="82" name="Write Document (2)" width="90" x="179" y="85"><br> <parameter key="file" value="C:\Users\r\P4_XML_TCP\testoutput\%{file_name}"/><br> </operator><br> <connect from_port="single" to_op="Write Document (2)" to_port="document"/><br> <connect from_op="Write Document (2)" from_port="document" to_port="output 1"/><br> <connect from_op="Write Document (2)" from_port="file" to_port="output 2"/><br> <portSpacing port="source_single" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> <portSpacing port="sink_output 2" spacing="0"/><br> <portSpacing port="sink_output 3" spacing="0"/><br> </process><br> </operator><br> <connect from_op="Loop Files" from_port="output 1" to_op="Loop Collection" to_port="collection"/><br> <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
<?xml version="1.0" encoding="UTF-8"?><process version="9.10.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="concurrency:loop_files" compatibility="8.2.000" expanded="true" height="82" name="Loop Files" width="90" x="112" y="34"> <parameter key="directory" value="C:\Users\r\P4_XML_TCP\test"/> <parameter key="filter_type" value="glob"/> <parameter key="filter_by_glob" value="*.txt"/> <parameter key="recursive" value="false"/> <parameter key="enable_macros" value="true"/> <parameter key="macro_for_file_name" value="file_name"/> <parameter key="macro_for_file_type" value="file_type"/> <parameter key="macro_for_folder_name" value="folder_name"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="9.3.001" expanded="true" height="68" name="Read Document" width="90" x="246" y="34"> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_port="file object" to_op="Read Document" to_port="file"/> <connect from_op="Read Document" from_port="output" to_port="output 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_collection" compatibility="9.10.000" expanded="true" height="82" name="Loop Collection (2)" width="90" x="313" y="34"> <parameter key="set_iteration_macro" value="false"/> <parameter key="macro_name" value="iteration"/> <parameter key="macro_start_value" value="1"/> <parameter key="unfold" value="true"/> <process expanded="true"> <operator activated="true" class="text:cut_document" compatibility="8.2.000" expanded="true" height="68" name="Cut Document" width="90" x="246" y="34"> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"> <parameter key="sentence" value="(.+)"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="9.3.001" expanded="true" height="68" name="Tokenize" width="90" x="246" y="34"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="9.3.001" expanded="true" height="68" name="Transform Cases" width="90" x="380" y="34"> <parameter key="transform_to" value="lower case"/> </operator> <connect from_port="segment" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_port="single" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_collection" compatibility="9.10.000" expanded="true" height="103" name="Loop Collection" width="90" x="514" y="34"> <parameter key="set_iteration_macro" value="false"/> <parameter key="macro_name" value="iteration"/> <parameter key="macro_start_value" value="1"/> <parameter key="unfold" value="true"/> <process expanded="true"> <operator activated="true" class="multiply" compatibility="9.10.000" expanded="true" height="103" name="Multiply" width="90" x="112" y="85"/> <operator activated="true" class="text:write_document" compatibility="9.3.001" expanded="true" height="82" name="Write Document (2)" width="90" x="313" y="187"> <parameter key="file" value="C:\Users\r\P4_XML_TCP\testoutput\%{file_name}prep.%{file_type}"/> <parameter key="overwrite" value="true"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="9.3.001" expanded="true" height="82" name="Documents to Data" width="90" x="313" y="34"> <parameter key="text_attribute" value="file_name"/> <parameter key="label_attribute" value="file_name"/> <parameter key="add_meta_information" value="true"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <parameter key="use_processed_text" value="false"/> </operator> <operator activated="true" class="extract_macro" compatibility="9.10.000" expanded="true" height="68" name="Extract Macro" width="90" x="447" y="34"> <parameter key="macro" value="file_name"/> <parameter key="macro_type" value="number_of_examples"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value=""/> <list key="additional_macros"/> </operator> <connect from_port="single" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Write Document (2)" to_port="document"/> <connect from_op="Documents to Data" from_port="example set" to_op="Extract Macro" to_port="example set"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> <portSpacing port="sink_output 3" spacing="0"/> </process> </operator> <connect from_op="Loop Files" from_port="output 1" to_op="Loop Collection (2)" to_port="collection"/> <connect from_op="Loop Collection (2)" from_port="output 1" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/> <connect from_op="Loop Collection" from_port="output 2" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
