Altair RISE
Nominate Yourself Now!
Text Processing - Cut Document - Similar entries separated by a number
User: "exmenace"
New Altair Community Member
Updated by Jocelyn
I was having trouble finding the operator documentation that pertains to string matching or cutting documents in general.
I have a few different types of documents (.xml, .csv, .docx, .html) that list records, in order, separated by *Record (n)* in ascending numbers, starting with 1.
Each of these records has similar attributes but it's all unformatted other than the records and attributes being separated by asterisks*.
My hope was to cut the document by record, which I assumed I could do with a string matching query, but I'm not sure how I could do that if each record is different, and the only commonality being the record #, but that's variable so not sure how to input that expression.
1 - 1 of 11
    User: "kayman"
    Accepted Answer
    Are your records each time on a new line?
    like :
    Record 1*something*someting else*and again something else
    Record 2*something*someting else*and again something else
    Record 3*something*someting else*and again something else
    or is it more like
    Record 1*something*someting else*and again something else*Record 2*something*someting else*and again something else*Record 3*something*someting else*and again something else
    In case of the first you could simply use the read csv operator and use the * as the separator. Beware that this is a special character that needs to be escaped, so in order to use it correct you need to enter \* instead of just *
    You could also use the split operator, same here. Use \* to make clear you want to split on the 'normal' asterix.
    If all is in one line I recommend to use the split document into collection from the toolbox extension.
    I've attached some samples to play around with, hope they get you started.
