<?xml version="1.0" encoding="UTF-8"?><process version="9.10.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.10.000" expanded="true" height="68" name="Golf" origin="GENERATED_TUTORIAL" width="90" x="179" y="85"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.4.000" expanded="true" height="103" name="Decision Tree" origin="GENERATED_TUTORIAL" width="90" x="581" y="85"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="20"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.25"/> <parameter key="apply_prepruning" value="true"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <operator activated="true" class="log" compatibility="9.10.000" expanded="true" height="82" name="Log" width="90" x="447" y="289"> <list key="log"> <parameter key="Retrieve DS" value="operator.Golf.value.execution-time"/> <parameter key="Decision Tree" value="operator.Decision Tree.value.execution-time"/> <parameter key="Process Execution Time (ms)" value="operator.Process.value.time"/> <parameter key="Process Used Memory (bytes)" value="operator.Process.value.memory"/> </list> <parameter key="sorting_type" value="none"/> <parameter key="sorting_k" value="100"/> <parameter key="persistent" value="false"/> </operator> <operator activated="true" class="log_to_data" compatibility="9.10.000" expanded="true" height="103" name="Log to Data" width="90" x="581" y="289"/> <operator activated="true" class="extract_macro" compatibility="9.10.000" expanded="true" height="68" name="Extract Macro" width="90" x="715" y="289"> <parameter key="macro" value="MS"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="Process Execution Time (ms)"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="print_to_console" compatibility="9.10.000" expanded="true" height="82" name="Print to Console" width="90" x="849" y="289"> <parameter key="log_value" value="Executed in %{MS} milliseconds"/> </operator> <connect from_op="Golf" from_port="output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Log" from_port="through 1" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Print to Console" to_port="through 1"/> <connect from_op="Print to Console" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="42"/> <portSpacing port="sink_result 2" spacing="21"/> </process> </operator> </process>
