<?xml version="1.0" encoding="UTF-8"?><process version="9.9.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="concurrency:loop_files" compatibility="9.9.002" expanded="true" height="82" name="Loop Folder With Files" width="90" x="179" y="85"> <parameter key="filter_type" value="regex"/> <parameter key="filter_by_regex" value="(?i).*docx"/> <parameter key="recursive" value="false"/> <parameter key="enable_macros" value="false"/> <parameter key="macro_for_file_name" value="file_name"/> <parameter key="macro_for_file_type" value="file_type"/> <parameter key="macro_for_folder_name" value="folder_name"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="9.3.001" expanded="true" height="68" name="Read Document" width="90" x="246" y="34"> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_port="file object" to_op="Read Document" to_port="file"/> <connect from_op="Read Document" from_port="output" to_port="output 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="operator_toolbox:lda" compatibility="2.11.000" expanded="true" height="124" name="Extract Topics from Documents (LDA)" width="90" x="380" y="85"> <parameter key="number_of_topics" value="10"/> <parameter key="show_optimization_settings" value="false"/> <parameter key="use_alpha_heuristics" value="true"/> <parameter key="alpha_sum" value="0.1"/> <parameter key="use_beta_heuristics" value="true"/> <parameter key="beta" value="0.01"/> <parameter key="optimize_hyperparameters" value="true"/> <parameter key="optimize_interval_for_hyperparameters" value="10"/> <parameter key="iterations" value="1000"/> <parameter key="top_words_per_topic" value="5"/> <parameter key="stopword language" value="english"/> <parameter key="reproducible" value="false"/> <parameter key="enable_logging" value="false"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="include_meta_data" value="true"/> </operator> <connect from_op="Loop Folder With Files" from_port="output 1" to_op="Extract Topics from Documents (LDA)" to_port="col"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
