I am doing modeling from rapidminer and everything works good but I am not understanding the confidence and prediction that It generates. I have YES and NO as outcome variable. This is how it looks like,
How does the confidence relates to the prediction? As you can see even with higher percentage of NO confidence it is predicting YES. After 0.42 it starting to predict NO. Isn't it like, if the confidence(NO) is above 0.5 then it should predict NO otherwise YES. What is the threshold value for the confidence to predict YES or NO?
Any help is appreciated. Thanks
