<?xml version="1.0" encoding="UTF-8"?><process version="9.9.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.9.002" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="multiply" compatibility="9.9.002" expanded="true" height="124" name="Multiply" width="90" x="179" y="34"/> <operator activated="true" class="aggregate" compatibility="9.9.002" expanded="true" height="82" name="Aggregate max" width="90" x="313" y="238"> <parameter key="use_default_aggregation" value="true"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="maximum"/> <list key="aggregation_attributes"/> <parameter key="group_by_attributes" value=""/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="aggregate" compatibility="9.9.002" expanded="true" height="82" name="Aggregate avg" width="90" x="313" y="34"> <parameter key="use_default_aggregation" value="true"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"/> <parameter key="group_by_attributes" value=""/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="aggregate" compatibility="9.9.002" expanded="true" height="82" name="Aggregate min" width="90" x="313" y="136"> <parameter key="use_default_aggregation" value="true"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="minimum"/> <list key="aggregation_attributes"/> <parameter key="group_by_attributes" value=""/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="cartesian_product" compatibility="9.9.002" expanded="true" height="82" name="Cartesian first" width="90" x="514" y="34"> <parameter key="remove_double_attributes" value="true"/> </operator> <operator activated="true" class="cartesian_product" compatibility="9.9.002" expanded="true" height="82" name="Cartesian second" width="90" x="648" y="85"> <parameter key="remove_double_attributes" value="true"/> </operator> <operator activated="true" class="de_pivot" compatibility="9.9.002" expanded="true" height="82" name="De-Pivot" width="90" x="782" y="85"> <list key="attribute_name"> <parameter key="average" value="average.+"/> <parameter key="min" value="minimum.+"/> <parameter key="max" value="maximum.+"/> </list> <parameter key="index_attribute" value="idx"/> <parameter key="create_nominal_index" value="false"/> <parameter key="keep_missings" value="false"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Aggregate avg" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Aggregate min" to_port="example set input"/> <connect from_op="Multiply" from_port="output 3" to_op="Aggregate max" to_port="example set input"/> <connect from_op="Aggregate max" from_port="example set output" to_op="Cartesian second" to_port="right"/> <connect from_op="Aggregate avg" from_port="example set output" to_op="Cartesian first" to_port="left"/> <connect from_op="Aggregate min" from_port="example set output" to_op="Cartesian first" to_port="right"/> <connect from_op="Cartesian first" from_port="join" to_op="Cartesian second" to_port="left"/> <connect from_op="Cartesian second" from_port="join" to_op="De-Pivot" to_port="example set input"/> <connect from_op="De-Pivot" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="42"/> <portSpacing port="sink_result 2" spacing="84"/> </process> </operator> </process>
This is probably more flexible than just getting the metadata. You can set breakpoints on the operators to see their intermediate results.
Balázs
