 I would like to split the line in the middle so that I can make the boundary condition on a meshing node. So when I mesh the component there should be a ‚Mesh node‘ instead of a node which I could build with the tool ‚nodes‘ or ‚node edit‘. Because when I import the model in Abaqus, Abaqus only recognizes the boundary conditions on a ‚Meshing point‘. Thanks in advance for your help.
