<?xml version="1.0" encoding="UTF-8"?><process version="9.9.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.9.002" expanded="true" height="68" name="Dates" width="90" x="45" y="85"> <parameter key="generator_type" value="date series"/> <parameter key="number_of_examples" value="3"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"> <parameter key="Date" value="2021-06-01 00:00:00.2021-06-07 00:00:00"/> </list> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="generate_data" compatibility="9.9.002" expanded="true" height="68" name="Generate Data" width="90" x="45" y="187"> <parameter key="target_function" value="random"/> <parameter key="number_examples" value="3"/> <parameter key="number_of_attributes" value="1"/> <parameter key="attributes_lower_bound" value="2.0"/> <parameter key="attributes_upper_bound" value="5.0"/> <parameter key="gaussian_standard_deviation" value="10.0"/> <parameter key="largest_radius" value="10.0"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="operator_toolbox:merge" compatibility="2.10.000" expanded="true" height="103" name="Merge Attributes" width="90" x="246" y="136"> <parameter key="handling_of_duplicate_attributes" value="rename"/> <parameter key="handling_of_special_attributes" value="keep_first_special_other_regular"/> <parameter key="handling_of_duplicate_annotations" value="rename"/> </operator> <operator activated="true" class="generate_copy" compatibility="9.9.002" expanded="true" height="82" name="Generate Copy" width="90" x="45" y="340"> <parameter key="attribute_name" value="Date"/> <parameter key="new_name" value="Date_Nominal"/> </operator> <operator activated="true" class="generate_copy" compatibility="9.9.002" expanded="true" height="82" name="Generate Copy (2)" width="90" x="179" y="340"> <parameter key="attribute_name" value="Date"/> <parameter key="new_name" value="Date_minus_24hrs"/> </operator> <operator activated="true" class="adjust_date" compatibility="9.9.002" expanded="true" height="82" name="Adjust Date" width="90" x="313" y="340"> <parameter key="attribute_name" value="Date_minus_24hrs"/> <list key="adjustments"> <parameter key="-1" value="Day"/> </list> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="9.9.002" expanded="true" height="82" name="Date to Nominal" width="90" x="447" y="340"> <parameter key="attribute_name" value="Date_Nominal"/> <parameter key="date_format" value="yyy-MM-dd hh:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.9.002" expanded="true" height="82" name="Generate Attributes" width="90" x="581" y="340"> <list key="function_descriptions"> <parameter key="att1" value="round(att1,0)"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="loop_examples" compatibility="9.9.002" expanded="true" height="103" name="Loop Examples" width="90" x="715" y="340"> <parameter key="iteration_macro" value="example"/> <process expanded="true"> <operator activated="true" class="date_to_nominal" compatibility="9.9.002" expanded="true" height="82" name="Date to Nominal (2)" width="90" x="45" y="34"> <parameter key="attribute_name" value="Date_minus_24hrs"/> <parameter key="date_format" value="yyyy-MM-dd hh:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="extract_macro" compatibility="9.9.002" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="34"> <parameter key="macro" value="From"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="Date_minus_24hrs"/> <parameter key="example_index" value="%{example}"/> <list key="additional_macros"> <parameter key="To" value="Date_minus_24hrs"/> <parameter key="Count" value="att1"/> </list> </operator> <operator activated="true" class="concurrency:loop" compatibility="9.9.002" expanded="true" height="82" name="Loop" width="90" x="447" y="34"> <parameter key="number_of_iterations" value="%{Count}"/> <parameter key="iteration_macro" value="iteration"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.9.002" expanded="true" height="68" name="Last 24 hrs with step size" width="90" x="380" y="34"> <parameter key="generator_type" value="date series"/> <parameter key="number_of_examples" value="90"/> <parameter key="use_stepsize" value="true"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"> <parameter key="Date" value="%{From}.%{To}"/> </list> <list key="date_series_configuration (interval)"> <parameter key="Date" value="%{From}.15.minute"/> </list> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <connect from_op="Last 24 hrs with step size" from_port="output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Date to Nominal (2)" to_port="example set input"/> <connect from_op="Date to Nominal (2)" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Loop" from_port="output 1" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="9.9.002" expanded="true" height="82" name="Append" width="90" x="916" y="187"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <connect from_op="Dates" from_port="output" to_op="Merge Attributes" to_port="example set 1"/> <connect from_op="Generate Data" from_port="output" to_op="Merge Attributes" to_port="example set 2"/> <connect from_op="Merge Attributes" from_port="merged set" to_op="Generate Copy" to_port="example set input"/> <connect from_op="Generate Copy" from_port="example set output" to_op="Generate Copy (2)" to_port="example set input"/> <connect from_op="Generate Copy (2)" from_port="example set output" to_op="Adjust Date" to_port="example set input"/> <connect from_op="Adjust Date" from_port="example set output" to_op="Date to Nominal" to_port="example set input"/> <connect from_op="Date to Nominal" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
