what is the operator to get the information as before the group by/aggregate operation?
Anusha
Hi All!
can anyone help with the opposite operator for the group by/aggregate?
I have the data on which someone has done group by of few attributes and aggregating few attributes. but I want the source data as it is.
sample input:
att1 attr2 attr3 attr4 attr5
789 gg|;bj jd|;bd 89|;09 78|;87
output required:
789 gg jd 89 78
789 bj bd 09 87
Thanks in advance!
BalazsBaranyRM
Hi
@Anusha
probably you have more elements in one attribute than in the other.
Look at the data and search for the attribute with the largest number of elements. E. g. if attr1 has 4 elements, every attribute needs to have that number after the split. E. g. attr2_1, attr2_2, attr2_3, attr2_4. You can use Generate Attributes to create the empty attributes.
De-Pivot needs the structure to be identical between the attributes.
Balázs
BalazsBaranyRM
Hi
@Anusha
if you use Split with the regular expression \|; you'll get attributes of the form attr2_1, attr2_2, attr3_1, attr3_2 etc. The contents will be the original values split up accordingly.
Then you can use De-Pivot. Index attribute is whatever you choose (a name not yet used in the example set), and in the attribute name list you can enter the different attributes:
attr2 attr2.+
attr3 attr3.+
etc.
This will put the split attributes (identified by the regular expression) on the rows.
Balázs
Anusha
Hi
@BalazsBarany
actually, I have tried this process already but I'm getting an error.
"mis matched attribute selection. the number attributes for attr1 and attr2 is different"
How can I resolve this issue?
BalazsBaranyRM
Hi
@Anusha
Balázs
