How run rapidminer in backgorund from command line
Amek
Hello, I run process from the command line:
rapidminer-batch.bat -f DIRECTORY/process.rmp from c# code and it takes a lot of time for example running this process from GUI takes 4-5s but in command line about 35-40s.
Is there any way to have Studio running in the background so that it doesn't have to be started up every time a process is executed from the command line?
MartinLiebig
thats what we have our AI Hub with always-on JVMs for. Also please keep license agreements in mind when using the CLI.
Best,
Martin
Amek
I installed AI Hub and run it. Now how I can change this line: rapidminer-batch.bat -f DIRECTORY/process.rmp to run it in ai hub?
MartinLiebig
Likely you want to expose the process as a WS which submit into the queue. I would recommend that you connect to your customer success manager so we can have a look together.
Amek
I created web service and it runs my process. But its possible to change process file in this service?
MartinLiebig
Hi
@Amek
see:
https://docs.rapidminer.com/9.7/server/install/extensions/
best,
Martin
Amek
Now it works thanks! But I have another problem, lets say I have about 10k processes it's possible to store them in ai hub and run automatically? Or Can I change process file in created web service? I want run this service 10k times but each time with a different file process
MartinLiebig
you could just use a macro for the path you want to write. Those get translated to GET-Parameters and then you can sent different parameters from your C#-Code. Be sure not to kill the server with 10k requests though.
~Martin
