When I define a spherical point source using EDITFEKO (for instance Qsmn=Q112) the total near- and far-field are both defined using Etot = Etheta+Ephi.
 The EDITFEKO code: AS: 0 : -4 : 1 : 1 : 2 : 1 : 0 : 0 : 0 : 1 :  :  : 1
However when using a waveguide port, for instance for a horn antenna, then it is consistent with the documentation with Etot = sqrt(Etheta^2+Ephi^2).
 Can somebody point out to me why this definition in the total field changes when using the equivalent source source; spherical mode.
