Maybe I'm doing something wrong but I don't understand why this replacement regex adds "MyString" after $1.
Thanks in advance
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.9.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.9.000" expanded="true" height="68" name="Create ExampleSet (3)" width="90" x="45" y="34">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="Attribute01 202104"/>
<parameter key="column_separator" value=","/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<operator activated="true" breakpoints="after" class="rename_by_replacing" compatibility="9.9.000" expanded="true" height="82" name="Rename by Replacing" width="90" x="179" y="34">
<parameter key="attribute_filter_type" value="value_type"/>
<parameter key="attribute" value=""/>
<parameter key="value_type" value="integer"/>
<parameter key="replace_what" value="(.*)"/>
<parameter key="replace_by" value="MyString$1"/>
<connect from_op="Create ExampleSet (3)" from_port="output" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/>
</process>
</process>
