?xml version="1.0" encoding="UTF-8"?><process version="9.9.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.9.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.9.000" expanded="true" height="68" name="Retrieve Golf" width="90" x="112" y="187"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.9.000" expanded="true" height="103" name="Decision Tree" width="90" x="246" y="187"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="10"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.1"/> <parameter key="apply_prepruning" value="true"/> <parameter key="minimal_gain" value="0.01"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <operator activated="true" class="operator_toolbox:get_dectree_path" compatibility="2.10.000" expanded="true" height="82" name="Get Decision Tree Path" width="90" x="447" y="187"/> <operator activated="true" class="aggregate" compatibility="9.9.000" expanded="true" height="82" name="Aggregate" width="90" x="581" y="187"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="Path" value="count"/> </list> <parameter key="group_by_attributes" value="Path"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <connect from_op="Retrieve Golf" from_port="output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_op="Get Decision Tree Path" to_port="mod"/> <connect from_op="Decision Tree" from_port="exampleSet" to_op="Get Decision Tree Path" to_port="exa"/> <connect from_op="Get Decision Tree Path" from_port="exa" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
