Hi ,.....I have two attributes which contain text data.How to find fuzzy match score of each row .
Harshav
I saw there is a fuzzy match function in generate attributes .But I'm facing this error
.Can anyone please help me with this ?
MartinLiebig
please have a look at the attached process, it works for me? Not sure what your exact expression ist.
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
<process expanded="true">
<operator activated="true" class="subprocess" compatibility="9.9.000" expanded="true" height="82" name="Subprocess" origin="GENERATED_TUTORIAL" width="90" x="112" y="34">
<operator activated="true" class="generate_data_user_specification" compatibility="9.9.000" expanded="true" height="68" name="Generate Data by User Specification" origin="GENERATED_TUTORIAL" width="90" x="45" y="34">
<list key="attribute_values">
<parameter key="Attribute1" value=""abc""/>
<parameter key="Attribute2" value=""ab""/>
</list>
<operator activated="true" class="generate_data_user_specification" compatibility="9.9.000" expanded="true" height="68" name="Generate Data by User Specification (2)" origin="GENERATED_TUTORIAL" width="90" x="45" y="136">
<parameter key="Attribute1" value=""xxx""/>
<parameter key="Attribute2" value=""yyy""/>
</list>
<operator activated="true" class="generate_data_user_specification" compatibility="9.9.000" expanded="true" height="68" name="Generate Data by User Specification (3)" origin="GENERATED_TUTORIAL" width="90" x="45" y="238">
<parameter key="Attribute1" value=""This is one Text""/>
<parameter key="Attribute2" value=""This is another Text""/>
</list>
<operator activated="true" class="generate_data_user_specification" compatibility="9.9.000" expanded="true" height="68" name="Generate Data by User Specification (4)" origin="GENERATED_TUTORIAL" width="90" x="45" y="340">
<parameter key="Attribute1" value=""ABC""/>
<parameter key="Attribute2" value=""abc""/>
</list>
<operator activated="true" class="append" compatibility="9.9.000" expanded="true" height="145" name="Append" origin="GENERATED_TUTORIAL" width="90" x="246" y="85">
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
<parameter key="merge_type" value="all"/>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/>
<connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/>
<connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/>
<connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append" to_port="example set 4"/>
<connect from_op="Append" from_port="merged set" to_port="out 1"/>
</process>
<description align="center" color="transparent" colored="false" width="126">Generate Example Data</description>
<operator activated="true" class="generate_attributes" compatibility="9.9.000" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="34">
<parameter key="distance" value="fuzzy_match(Attribute1,Attribute2,LEVENSHTEIN_TOKEN_SET_RATIO)"/>
</list>
<parameter key="keep_all" value="true"/>
<connect from_op="Subprocess" from_port="out 1" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
Harshav
This is my expression,dont know why its throwing error
Harshav
And FYI , I'm using this function in sparkrm radoop operator.
Harshav
Harshav
@mschmitz
