When I load any process into RM 9.9, I get the attached error saying "Operator 'Process' was created with version '9.4.000'.
Log file states "Cannot register renderer" and none of the chromium.exe processes load: Here's a snippet from the log:
INFO: Global Search category repository registered.
May 13, 2021 10:11:18 AM com.rapidminer.tools.plugin.Plugin initAll
INFO: Plugins skipped.
May 13, 2021 10:11:18 AM com.rapidminer.gui.renderer.RendererService registerRenderers
WARNING: Cannot register renderer: com.rapidminer.extension.html5charts.gui.renderer.ExampleSetVisualizationRenderer
java.lang.ClassNotFoundException: com.rapidminer.extension.html5charts.gui.renderer.ExampleSetVisualizationRenderer
at java.net.URLClassLoader.findClass(URLClassLoader.java:382)
I've been using 9.9 successfully since it was released several weeks ago - until May 12. I've reinstalled RM 9.9 multiple times but continue to get the error shown in the attachment when loading any process.
I've tried a clean reinstall of the NVidia driver and installing Google Chrome, each followed by RM reinstalls, but chromium still won't load and the errors are the same..
Also tried editing the RapidMiner-Studio.bat file as suggested in another post - still won't load the GUI:
rem ## "%JAVA%" %JVM_OPTIONS% -cp "%RAPIDMINER_HOME%"\lib\* com.rapidminer.launcher.GUILauncher %CMD_LINE_ARGS%
"%JAVA%" %JVM_OPTIONS% -Dsun.java2d.d3d=false -Dsun.java2d.opengl=true -cp "%RAPIDMINER_HOME%"\lib\*;"%RAPIDMINER_HOME%"\lib\jdbc\* com.rapidminer.launcher.GUILauncher %CMD_LINE_ARGS%
This issue may be related to hardware acceleration enabled by the new NVidia drivers. Before my machine refused to run RM, javaw.exe was
heavily using both the GPU and CPU simultaneously while modeling and computing. It seemingly worked well. When the RM process finished, the GPU use would drop back to zero while the RM UI was still open. Chromium may not have liked this and now refuses to run with my graphics driver (466.27). If this is the case, I may need to disable HW acceleration or find another graphics driver.
