Hi, I would like to use HyperGraph to analyse and present the results of the MOGA optimisation done with HyperStudy.
What kind of file should be generated with HyperStudy to give it to Hypergraph for the post processing please ?
Kind regards
Bonjour Damien,
A double click on an image in HyperStudy, opens automatically a HyperGraph session and you can do further post-processing. Does this work for you?
Out of curiosity, what further analysis do you need to do? Feel free to share more details in case if I can provide you alternative suggestions.
Kind regards,
Diana
Bonjour Damien, A double click on an image in HyperStudy, opens automatically a HyperGraph session and you can do further post-processing. Does this work for you? Out of curiosity, what further analysis do you need to do? Feel free to share more details in case if I can provide you alternative suggestions. Kind regards, Diana
Bonjour Diana,
Thanks for the fast answer. The solution you proposed works well, it opens HyperGraph.
I would like to be able to present a graph of the volume as function of efficiency with color to illustrate the evolution of a third parameter on this 2D graph, like the attached image. I would like to do it on HyperGraph because of the possibility to adapt the police of the axis.
The possibility of drawing curves or histograms of several parameters as a function of efficiency, for example, would be great.
Bonjour Diana, Thanks for the fast answer. The solution you proposed works well, it opens HyperGraph. I would like to be able to present a graph of the volume as function of efficiency with color to illustrate the evolution of a third parameter on this 2D graph, like the attached image. I would like to do it on HyperGraph because of the possibility to adapt the police of the axis. The possibility of drawing curves or histograms of several parameters as a function of efficiency, for example, would be great.
I'd like to follow up with your last request about the multiple parameters display.
Below is an example of display you can get, where in the Channel a Goal function is selected in X Axis and several variables are selected in Y Axis (you see them identified with square, triangle,..symbols). On Bubble side another Goal function is selected in Color panel.
is this what you had in mind? Just wanted to share it in case it helps.
