Is there a way to make a geometrical parameter depend on another one and to define it as a driven parameter in a scenario? If this is not possible directly, is there an indirect method ?
Thank you in advance
Hello Damien;
All geometrical parameters can be driven from the scenario, but these parameters should be used by the geometry or Flux will return an error message.
If one parameter A is used in parameter B, so B can not be driven from the scenario.
Regards
