DATA TO DOCUMENT operator not working with JSON TO DATAClosed
User: "Somnath_Das"
New Altair Community Member
Updated by Jocelyn
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.7.000" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="read_csv" compatibility="9.7.000" expanded="true" height="68" name="Read CSV" width="90" x="179" y="34">
        <parameter key="column_separators" value=";"/>
        <parameter key="trim_lines" value="false"/>
        <parameter key="use_quotes" value="true"/>
        <parameter key="quotes_character" value="&quot;"/>
        <parameter key="escape_character" value="\"/>
        <parameter key="skip_comments" value="false"/>
        <parameter key="comment_characters" value="#"/>
        <parameter key="starting_row" value="1"/>
        <parameter key="parse_numbers" value="true"/>
        <parameter key="decimal_character" value="."/>
        <parameter key="grouped_digits" value="false"/>
        <parameter key="grouping_character" value=","/>
        <parameter key="infinity_representation" value=""/>
        <parameter key="date_format" value=""/>
        <parameter key="first_row_as_names" value="true"/>
        <list key="annotations"/>
        <parameter key="time_zone" value="SYSTEM"/>
        <parameter key="locale" value="English (United States)"/>
        <parameter key="read_all_values_as_polynominal" value="false"/>
        <list key="data_set_meta_data_information"/>
        <parameter key="read_not_matching_values_as_missings" value="true"/>
        <parameter key="datamanagement" value="double_array"/>
        <parameter key="data_management" value="auto"/>
      <operator activated="true" class="text:data_to_documents" compatibility="9.3.001" expanded="true" height="68" name="Data to Documents" width="90" x="313" y="34">
        <parameter key="select_attributes_and_weights" value="false"/>
        <list key="specify_weights"/>
      <operator activated="true" class="loop_collection" compatibility="9.7.000" expanded="true" height="82" name="Loop Collection" width="90" x="447" y="34">
        <parameter key="set_iteration_macro" value="true"/>
        <parameter key="macro_name" value="iteration"/>
        <parameter key="macro_start_value" value="1"/>
        <parameter key="unfold" value="false"/>
          <operator activated="true" class="text:json_to_data" compatibility="9.3.001" expanded="true" height="82" name="JSON To Data" width="90" x="179" y="34">
            <parameter key="ignore_arrays" value="false"/>
            <parameter key="limit_attributes" value="false"/>
            <parameter key="skip_invalid_documents" value="false"/>
            <parameter key="guess_data_types" value="false"/>
            <parameter key="keep_missing_attributes" value="true"/>
            <parameter key="missing_values_aliases" value=", null, NaN, missing"/>
          <connect from_port="single" to_op="JSON To Data" to_port="documents 1"/>
          <connect from_op="JSON To Data" from_port="example set" to_port="output 1"/>
          <portSpacing port="source_single" spacing="0"/>
          <portSpacing port="sink_output 1" spacing="0"/>
          <portSpacing port="sink_output 2" spacing="0"/>
        </process>
      <connect from_op="Read CSV" from_port="output" to_op="Data to Documents" to_port="example set"/>
      <connect from_op="Data to Documents" from_port="documents" to_op="Loop Collection" to_port="collection"/>
      <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/>
    </process>
</process>
The data to document operator is not working with the json to data operator. the sample data is also attached. I have a exampleset of a single column with json data and i want to process it with the json to data operator. Please help.
1 - 1 of 11
This post has been closed.
