Decision Tree depth and Parameter Optimisation
skewed_analysis
Hey!
I'm running parameter optimisation on a Decision Tree, however, the optimal parameters always output a higher depth value than the actual depth of the decision tree.
My flow is as follows:
1.
Optimize Parameters (Grid)
operator
2.
Cross Validation
inside the Optimize Parameters (Grid)
3.
Decision Tree
inside the Cross Validation (testing with
Apply Model
Performance Binomal Classification
I have pointed the selected parameters to be those of the correct decision tree (#3 above). The only parameter for optimisation is the Depth with values: min 1, max 20, steps 30.
For example, the optimization output gives me a max depth of 9, whereas inspecting the Decision Tree model output I can see that it only has a depth of three.
Am I making a mistake somewhere or can the optimal maximum depth of a decision tree be higher than the actual node depth that is used?
YYH
Hi
@skewed_analysis
Thanks for reporting that findings. If you disable both pruning and pre-pruning, the optimized tree depth should get closer to the actual depth. The max tree depth will limit the size of the tree that prevent overfitting. The final tree model could not have depth >= max_tree_depth
PS, you do not need to have 30 steps for an integer iterate from 1 to 20
Cheers,
YY
