How much memory should RM 9.9 allocate when starting without extensions?
Friedemann
When I start RapidMiner without setting any limits for the JVM it allocates 19GB of memory. Is that an intended behaviour?
Marco_Boeck
Where did you check that? Because you may mix up two different things:
1. This is the actual memory that is being used, as reported by the Windows Taskmanager in this case:
2. And here is the potentially usable, maximum memory that Studio will try to allocate if needed:
The 2nd one is the theoretical maximum Studio would try to get, but as you can see from the TaskManager, it is not actually taken yet.
Marco
Friedemann
I am using the Windows Resource Monitor
I have just started again and the process uses 9 GB of main memory.
And the task manager output:
Btw, these are the number after restricting the memory limits.
An now without a JVM memory limit:
