Newbie Temperature Forecast Model
User: "faisal63455"
New Altair Community Member
Updated by Jocelyn
Hi Community!
I am in the process of contemplating how I could build a model I have in mind in RapidMiner. I have listed below all the details I have in mind and would appreciate if some of you experienced RapidMiners out there can guide me in building this.
Background:
  • I have 11 features in my dataset that will be used to construct a forecast value for the next day of the target variable (target variable is temperature in this case). I have 15 years of daily data where each day records the temperature of that day and the 11 features (in one row). So, I have a total of about 5,475 observations (i.e.: 15 years * 365 days).
  • I know how I want the model to work but I am not really sure if this can be built on RapidMiner.
The thought flow works as follows:
  • For each day in the dataset, I want to find and collect the 50 most similar days for the 11 features in the dataset. (I assume I would need a kNN algo here or maybe cross distances or data-to-similarity operator?).
  • In the 50 most similar dataset, I want to then see what the temperature observed was on the NEXT day for these 50 days and compute the average temperature of the NEXT day for all of these 50 days. This is the “expected temperature” which can be used as a forecast to have an indication of the expected temperature tomorrow.
  • I want to start making forecasts after the first 2000 observations (this is the initial minimum window size). The window size is expanding as we reach 5,475 observations (which is today).
I hope this makes sense and thanks in advance for your support!
Thanks & Regards,
Faycal
No comments on this post.
