combining multiple columns into single column
Anusha
Hello Everyone,
I'm trying to combine the necessary columns with a delimiter as "," into a single column, but I'm unable to do that. can anyone please help me?
eg: input data: no of columns=5
reg no text1 text2 text3 text4
1 an apple keeps away
2 The sun rises in
required output: no of columns=2
reg no full text
1 an, apple, keeps, away
2 The, sun, rises, in
Thanks in Advance!
kayman
@Anusha
, Try as with attached. The aggregate operator contains a 'hidden' concatenation option which does exactly what you want.
It's comma separated now, but you can easily change the comma to |: or whatever you prefer.
kayman
The aggregate operator allows you to concatenate multiple columns, seperated by any token you like.
Anusha
@kayman
, aggregator combines row values but my requirement is combining column values to form a single column. by the way, can you please show, In aggregator where can we change the concatenation separator, the default one "|" but I want to change that to "|:", is it possible?
Telcontar120
@Anusha
I think the operator you want for this is Generate Concatenation.
This combines values from separate attributes into a single attribute, and you can also specify the separator character(s) you want to use between them.
kayman
@Anusha
kayman
@Telcontar120
, the standard concatenation works relatively fine if you have a limited number of known fields, but it's pretty cumbersome to combine multiple fields. The generate aggregation operator allows you to use regex to concatenate multiple attributes in one go, without the need to cleanup ;-)
The naming is just a bit confusing here...
