How can I change the name of columns
Loan_Nguyen56
Hello All,
I would like to change the three last column's names into "First Class", "Second Class", and "Third Class" instead of "Passenger First Class"... as well.
Thank you very much.
Loan Nguyen
Caperez
Hi
@Loan_Nguyen56
You have an operator named Rename into Blending-> Attributes->Names & Roles.
regards
Caperez
Hi
@Loan_Nguyen56
regards
Loan_Nguyen56
ceaperez
Thanks for your letting me know.
Besides that, I follow the instructions below to get the new column names however, I cannot get the right answer.
Renaming attributes with regular expressions
Search
for the operator
Rename by Replacing
add it, and connect it
to
Pivot
Also connect the operator to the result port on the right.
Copy
count\((.*)\)_(.*)
into the
replace what
parameter field. Make sure that you get all the parentheses right!
Copy
$1 $2
into the
replace by
parameter.
And, what does
count\((.*)\)_(.*)
means?
Thanks,
Caperez
Hi
@Loan_Nguyen56
They are replacing the names of the Attributes (Column) using a Regular Expression.
Probably their Attributes names are like count(something)_anotherthing
With this part count\((.*)\)_(.*) they are locating the two parametrized blocks after the string "count"
Then with $1 $2 instruction into the replace by parameter, they are replacing the original string by the first coincident block $1 (something) and the second coincidente block $2 (anotherthing)
you don't have a regular pattern in your Attributes names maybe is better to use another operator like Rename by Generic Name and write Passenger Class, for example.
Loan_Nguyen56
ceaperez
Wow, I understand it clearly.
Thank you very much for your kind help.
