Filter out Data for Scenario A=B,B=A then pick only one like A=B
sgnarkhede2016
I have Configuration File that contains combination Like
Att1 Att2
Customer beneficiary
beneficiary Customer
currency Customer
Customer Currency
receiver Sender
Scenario Like A=B,B=A then pick only one like A=B
Expected output
Att1 Att2
Customer Currency
receiver Sender
Thanks In Advance
kayman
This would require a lot of steps so not too sure if this is the best way to work on larger files.
The idea would be to first generate an ordered list and then remove all the duplicates, so you get only the unique combinations left.
Meaning if we have Customer Beneficiary the system would order them alphabetically so they become Beneficiary Customer instead. Once grouped only the unique ordered combinations remain.
Now, since you are mixing upper case and lower case (currency and Currency) you probably want to convert all to lower case also as these are not the same for a machine (lower cases will be sorted before upper case, or the other way around...)
Attached draft may get you started
draft.rmp
kayman
draft.rmp
