<?xml version="1.0" encoding="UTF-8"?><process version="9.8.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.8.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.8.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34"> <parameter key="generator_type" value="date series"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"> <parameter key="Fecha" value="2020-01-01.2021-01-01"/> </list> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="subprocess" compatibility="9.8.001" expanded="true" height="82" name="Copia_Fechas" width="90" x="179" y="34"> <process expanded="true"> <operator activated="true" class="generate_copy" compatibility="9.8.001" expanded="true" height="82" name="Generate Copy" width="90" x="45" y="34"> <parameter key="attribute_name" value="Fecha"/> <parameter key="new_name" value="Semana"/> </operator> <operator activated="true" class="generate_copy" compatibility="9.8.001" expanded="true" height="82" name="Generate Copy (2)" width="90" x="179" y="34"> <parameter key="attribute_name" value="Fecha"/> <parameter key="new_name" value="Día"/> </operator> <operator activated="true" class="generate_copy" compatibility="9.8.001" expanded="true" height="82" name="Generate Copy (3)" width="90" x="313" y="34"> <parameter key="attribute_name" value="Fecha"/> <parameter key="new_name" value="Día_Semana"/> </operator> <connect from_port="in 1" to_op="Generate Copy" to_port="example set input"/> <connect from_op="Generate Copy" from_port="example set output" to_op="Generate Copy (2)" to_port="example set input"/> <connect from_op="Generate Copy (2)" from_port="example set output" to_op="Generate Copy (3)" to_port="example set input"/> <connect from_op="Generate Copy (3)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.8.001" expanded="true" height="82" name="Semana_del_Año" width="90" x="313" y="34"> <parameter key="attribute_name" value="Semana"/> <parameter key="time_unit" value="week"/> <parameter key="millisecond_relative_to" value="second"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="month"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="9.8.001" expanded="true" height="82" name="Día_de_la_Semana" width="90" x="447" y="34"> <parameter key="attribute_name" value="Día_Semana"/> <parameter key="date_format" value="EEEE"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="Spanish (Mexico)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="9.8.001" expanded="true" height="82" name="Día_del_Mes" width="90" x="581" y="34"> <parameter key="attribute_name" value="Día"/> <parameter key="date_format" value="dd"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="Spanish (Mexico)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Copia_Fechas" to_port="in 1"/> <connect from_op="Copia_Fechas" from_port="out 1" to_op="Semana_del_Año" to_port="example set input"/> <connect from_op="Semana_del_Año" from_port="example set output" to_op="Día_de_la_Semana" to_port="example set input"/> <connect from_op="Día_de_la_Semana" from_port="example set output" to_op="Día_del_Mes" to_port="example set input"/> <connect from_op="Día_del_Mes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
