I am trying to use Mat Law 73 to model thermal and strain rate dependent material. I am facing problem while defining a field called Tab_ID as a part of the material law. The field is highlighted in the picture below. I went through the keypoints mentioned on the Mat Law 73 page (also attached in the picture below) but could not figure out how exactly the table should be defined. Kindly help me with this difficulty.
Thanks,
Madhura
