I'm trying to excute the following code by using Execute Python. I'd like to use the model tarined by this code in prediction phase.
import numpy as np
import pandas as pd
from tensorflow import keras
from tensorflow.keras import layers
def rm_main(data):
print(data.columns)
x_train = (data.drop(["Window id"],axis=1).values)[:, :, np.newaxis]
print(x_train.shape)
model = keras.Sequential(
layers.Input(shape=(x_train.shape[1], x_train.shape[2])),
layers.Conv1D(
filters=32, kernel_size=7, padding="same", strides=2, activation="relu"
layers.Dropout(rate=0.2),
layers.Conv1D(
filters=16, kernel_size=7, padding="same", strides=2, activation="relu"
layers.Conv1DTranspose(
layers.Conv1DTranspose(filters=1, kernel_size=7, padding="same"),
model.compile(optimizer=keras.optimizers.Adam(learning_rate=0.001), loss="mse")
model.summary()
history = model.fit(
x_train,
x_train,
epochs=50,
batch_size=128,
validation_split=0.1,
callbacks=[
keras.callbacks.EarlyStopping(monitor="val_loss", patience=5, mode="min")
return modelBut, I got the following error.
TypeError: can't pickle weakref objects
It's because keras sequential model is weakref object.
And I found this thead.
https://community.rapidminer.com/discussion/55837/see-the-python-script-of-keras-model
In this thead, I found the following post.
Indeed, this Python code was all crafted by hand. There is probably one more small detail worth mentioning - the Keras model is passed from Keras Model to Keras Evaluate by passing the path to the model saved on disk. At the time this seemed like the simplest solution, however, it should be possible to pass the model weights or a serialized model via RM ports.
I can successfully path the model by storing on disk. But, I'm wondering if there are another solution to pass Keras Model to prediction phaase without saving model on disk.
