   	I was going through the flux 2d technical tutorial for induction motor and in the case 3 section of the final, it is shown how to obtain the equivalent circuit model for the induction motor. However, upon using the equivalent circuit parameters for circuit simulation, I found that the stator current from the circuit simulation at the rated slip of 0.032 is way off the expected value of 8.48 A. Can anyone please explain? Thank you.
