<?xml version="1.0" encoding="UTF-8"?><process version="9.7.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.7.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.7.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="289"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="conjunction,replace also,§also besides,besides furthermore,§furthermore likewise,§likewise moreover,§moreover however,§however nevertheless,§nevertheless nonetheless,§nonetheless still,§still conversely,§conversely instead,§instead otherwise,§instead rather,§instead accordingly,§instead consequently,§instead hence,§instead meanwhile,§instead then,§instead therefore,§instead thus,§instead and,§and but,§but"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="utility:create_exampleset" compatibility="9.7.002" expanded="true" height="68" name="Create ExampleSet (2)" width="90" x="179" y="136"> <parameter key="generator_type" value="attribute functions"/> <parameter key="number_of_examples" value="1"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"> <parameter key="text" value=""The staff is bad, and the room is not good, but the food is great.""/> </list> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="text The staff is bad, and the room is not good, but the food is great."/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="replace_dictionary" compatibility="9.7.002" expanded="true" height="103" name="Replace (Dictionary)" width="90" x="380" y="187"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="text"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="from_attribute" value="conjunction"/> <parameter key="to_attribute" value="replace"/> <parameter key="use_regular_expressions" value="false"/> <parameter key="convert_to_lowercase" value="false"/> <parameter key="first_match_only" value="false"/> </operator> <operator activated="true" class="split" compatibility="9.7.002" expanded="true" height="82" name="Split" width="90" x="514" y="187"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="text"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="split_pattern" value="§"/> <parameter key="split_mode" value="ordered_split"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Replace (Dictionary)" to_port="dictionary"/> <connect from_op="Create ExampleSet (2)" from_port="output" to_op="Replace (Dictionary)" to_port="example set input"/> <connect from_op="Replace (Dictionary)" from_port="example set output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
