Hi
I had this process working yesterday, and for some reason I am not getting it right today. I am attempting to extract comments from Instagram for sentiment analysis, I need to search on the account level as well as the keyword level.
I am not great at Json paths, have I done these correctly? When I paste the URL's into a web browser I am getting a Json response.
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.7.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="187">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="term, search saradioawards, https://www.instagram.com/saradioawards/?__a=1 pfizer,https://www.instagram.com/pfizerinc/?__a=1 washington_post,https://www.instagram.com/coveringpotus/?__a=1"/>
<parameter key="column_separator" value=","/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<operator activated="true" class="loop_examples" compatibility="9.7.002" expanded="true" height="103" name="Loop Examples" width="90" x="313" y="187">
<parameter key="iteration_macro" value="example"/>
<operator activated="true" class="extract_macro" compatibility="9.7.002" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="34">
<parameter key="macro" value="search"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="statistics" value="average"/>
<parameter key="attribute_name" value="search"/>
<parameter key="example_index" value="%{example}"/>
<list key="additional_macros">
<parameter key="term" value="term"/>
</list>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="9.0.000" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="313" y="34">
<parameter key="query_type" value="JsonPath"/>
<list key="string_machting_queries"/>
<parameter key="attribute_type" value="Nominal"/>
<list key="regular_expression_queries">
<parameter key="foo" value=".*"/>
</list>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<parameter key="ignore_CDATA" value="true"/>
<parameter key="assume_html" value="true"/>
<list key="index_queries"/>
<list key="jsonpath_queries">
<parameter key="bio" value="$.graphql.user.biography"/>
<parameter key="full_name" value="$.graphql.user.full_name"/>
<parameter key="user_id" value="$.graphql.user.id"/>
<parameter key="is_business_account" value="$.graphql.user.is_business_account"/>
<parameter key="category_name" value="$.graphql.user.business_category_name"/>
<parameter key="category_enum" value="$.graphql.user.category_enum"/>
<parameter key="category_user" value="$.graphql.user.category_name"/>
<parameter key="connected_fb_page" value="$.graphql.user.connected_fb_page"/>
<parameter key="edges" value="$.graphql.user.edge_owner_to_timeline_media.edges"/>
</list>
<parameter key="request_method" value="GET"/>
<parameter key="url" value="%{search}"/>
<parameter key="delay" value="1000"/>
<list key="request_properties"/>
<parameter key="keep_sensitive_headers" value="true"/>
<operator activated="true" class="delay" compatibility="9.7.002" expanded="true" height="82" name="Delay" width="90" x="447" y="34">
<parameter key="delay" value="fixed"/>
<parameter key="delay_amount" value="6000"/>
<parameter key="min_delay_amount" value="0"/>
<parameter key="max_delay_amount" value="1000"/>
<description align="center" color="transparent" colored="false" width="126">Because Social networks can be sticky about scraping</description>
<connect from_port="example set" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Enrich Data by Webservice" to_port="Example Set"/>
<connect from_op="Enrich Data by Webservice" from_port="ExampleSet" to_op="Delay" to_port="through 1"/>
<connect from_op="Delay" from_port="through 1" to_port="output 1"/>
<portSpacing port="sink_example set" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="false" class="utility:create_exampleset" compatibility="9.7.002" expanded="true" height="68" name="Create ExampleSet (2)" width="90" x="179" y="391">
<parameter key="input_csv_text" value="term, search saradioawards, https://www.instagram.com/explore/tags/saradioawards/?__a=1&#10;pfizer,https://www.instagram.com/explore/tags/pfizer/?__a=1&#10;washington_post,https://www.instagram.com/explore/tags/washington post/?__a=1"/>
<operator activated="false" class="loop_examples" compatibility="9.7.002" expanded="true" height="103" name="Loop Examples (2)" width="90" x="313" y="391">
<operator activated="true" class="extract_macro" compatibility="9.7.002" expanded="true" height="68" name="Extract Macro (2)" width="90" x="179" y="34">
</list>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="9.0.000" expanded="true" height="68" name="Enrich Data by Webservice (2)" width="90" x="313" y="34">
</list>
<parameter key="search_id" value="$.graphql.hashtag.id"/>
<parameter key="search" value="$.graphql.hashtag.name"/>
<parameter key="posts" value="$.graphql.hashtag.edge_hashtag_to_media.count"/>
</list>
<operator activated="true" class="delay" compatibility="9.7.002" expanded="true" height="82" name="Delay (2)" width="90" x="447" y="34">
<parameter key="delay" value="random"/>
<parameter key="delay_amount" value="1000"/>
<parameter key="min_delay_amount" value="5000"/>
<parameter key="max_delay_amount" value="9000"/>
<connect from_port="example set" to_op="Extract Macro (2)" to_port="example set"/>
<connect from_op="Extract Macro (2)" from_port="example set" to_op="Enrich Data by Webservice (2)" to_port="Example Set"/>
<connect from_op="Enrich Data by Webservice (2)" from_port="ExampleSet" to_op="Delay (2)" to_port="through 1"/>
<connect from_op="Delay (2)" from_port="through 1" to_port="output 1"/>
</process>
<connect from_op="Create ExampleSet" from_port="output" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="output 1" to_port="result 1"/>
<description align="center" color="yellow" colored="false" height="169" resized="true" width="332" x="139" y="151">Keyword Search</description>
<description align="center" color="yellow" colored="false" height="171" resized="true" width="328" x="143" y="348">Account Search</description>
</process>
</process>
