Hi. I need some information about topology optimization stamping dies. I found presentation from Ford Otosan.
https://web.altairhyperworks.com/hubfs/2017_Germany/2017_06_EATC/Presentation Download/Tech Session 1/Ford_Otosan_Kadir_Akcan_Casting_Weight_Reduction.pdf?hsLang=en
Maybe someone can explain to me how to do dynamic analysis ?
Then I'm interested in how to export contact pressures force from autoform to hypermesh ?
You could refer to HyperForm (Manufacturing solution Interface)tutorials.
HF-5000: Using Result Mapper in HyperCrash
In this tutorial, you will learn the procedure for mapping forming results onto structural models using the HyperWorks Results Mapper.
HF-6000: Die Structure Optimization
Hi.
I understand but, is it possible to export contact forces from autoform ?
Where can I get parts for calculations HF-6000: Die Structure Optimization ?
Can someone say something about dynamics analysis ? Maybe some examples of how to define dynamic analysis ?
