<?xml version="1.0" encoding="UTF-8"?><process version="9.8.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.8.001" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="image_handling:read_image_meta_data" compatibility="0.2.001" expanded="true" height="68" name="Read Image Meta Data" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"> <parameter key="directory" value="/home/jacob/Pictures/Wallpapers"/> <parameter key="use_label" value="false"/> </operator> <operator activated="true" class="image_handling:read_image_as_exampleset" compatibility="0.2.001" expanded="true" height="68" name="Read Image as ExampleSet" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"> <parameter key="path" value="Path"/> <parameter key="height" value="Height"/> <parameter key="width" value="Width"/> <parameter key="number_of_color_channels" value="1"/> </operator> <operator activated="true" class="flatten_collection" compatibility="9.8.001" expanded="true" height="68" name="Flatten Collection" width="90" x="313" y="34"/> <operator activated="true" class="loop_collection" compatibility="9.8.001" expanded="true" height="82" name="Loop Collection" width="90" x="447" y="34"> <parameter key="set_iteration_macro" value="true"/> <parameter key="macro_name" value="iteration"/> <parameter key="macro_start_value" value="1"/> <parameter key="unfold" value="false"/> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="9.8.001" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="34"> <parameter key="macro" value="last_attr"/> <parameter key="macro_type" value="number_of_attributes"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value=""/> <list key="additional_macros"/> </operator> <operator activated="true" class="filter_example_range" compatibility="9.8.001" expanded="true" height="82" name="Filter Example Range" width="90" x="313" y="34"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="100"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="remove_attribute_range" compatibility="9.8.001" expanded="true" height="82" name="Remove Attribute Range" width="90" x="447" y="34"> <parameter key="first_attribute" value="101"/> <parameter key="last_attribute" value="%{last_attr}"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.8.001" expanded="true" height="82" name="Generate Attributes" width="90" x="581" y="34"> <list key="function_descriptions"> <parameter key="imageno" value="%{iteration}"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_port="single" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Remove Attribute Range" to_port="example set input"/> <connect from_op="Remove Attribute Range" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="9.8.001" expanded="true" height="82" name="Append" width="90" x="581" y="34"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <operator activated="true" class="set_role" compatibility="9.8.001" expanded="true" height="82" name="Set Role" width="90" x="715" y="34"> <parameter key="attribute_name" value="imageno"/> <parameter key="target_role" value="batch"/> <list key="set_additional_roles"/> </operator> <connect from_op="Read Image Meta Data" from_port="output" to_op="Read Image as ExampleSet" to_port="example set"/> <connect from_op="Read Image as ExampleSet" from_port="collection" to_op="Flatten Collection" to_port="collection"/> <connect from_op="Flatten Collection" from_port="flat" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <description align="left" color="yellow" colored="false" height="50" resized="true" width="327" x="39" y="126">Set the directory to a path which contains images.</description> </process> </operator> </process>
