🎉Community Raffle - Win $25
Join and Win
Export Time Domain results using lua script
User: "Zakaria"
Altair Community Member
Updated by Zakaria
I have a  time-domain excitation pulse (generated using Matlab as a .txt file). this excitation needs to be imported to PostFeko, calculate the time domain voltage across the load (in postfeko), then export the TD voltage to .dat or .txt file. I need to run all of this through Lua script. If I can do so then instead of reopening postFEKo every time I change the excitation pulse I can run the script through Matlab.
I have attached a basic Lua script that reads the current across the load and exports the data to the .dat file. However, it exports the Frequency domain data, not the Time domain. I have a very very basic knowledge of LUA scripting. I would really appreciate it If anyone has an idea of how to modify the script to perform the above tasks.
attached the FEKo Files and the Lua script.
1 - 3 of 31
    User: "Mel"
    Updated by Mel
    You could use ExportTraces:
    graph=app.CartesianGraphs[1]
    graph:ExportTraces("mydata.txt",101)
    User: "Zakaria"
    OP
    Updated by Zakaria
    Thanks for the replay. What command can I use to import the time domain signal file?
    User: "Mel"
    Updated by Mel
    Unfortunately automation and data set access for Time Analysis are not supported in POSTFEKO.
    So you would not be able to automate everything that you are after.
