Performance (cost) sample not behaving as expected
MaartenK
I was looking into the performance (cost) component. It comes with a tutorial. The tutorial applies naive bayes to the Golf dataset using split validation. The outcome should be that 1 of 4 items is misclassified. However, if i run it, all items are misclasified as follows (play -> prediction):
yes -> no, no-> yes, yes -> no, yes -> no).
My collegue did not have this result. I am running this on an AMD Ryzen 5 3600 with RapidMiner 9.8.001.
I did not change any of the paramters in the tutorial.
I Also rebuild the model from scratch which had the same results.
Performance
lionelderkrikor
Hi
@MaartenK
I'm only able to reproduce what you observe if :
- I check
use local random seed
and
local random seed = 1992
in the parameters of
Split Validation
operator
Otherwise if
is unchecked, i have in deed 25 % of the sample misclassified like your colleague ….
Thus are your sure that you have not checked
Split Validation
operator.
Lionel
lionelderkrikor
Hi
@MaartenK
- I check
and
Split Validation
operator
Otherwise if
Split Validation
operator.
Lionel
MaartenK
Hi Lionel,
That must be it. 1992 was the default local random seed in previous versions of RM and i set at as default to be able to reproduce the results from my thesis. The current default is 2001. If I use that then it works as described in the help.
Still interesting how that would generate such different results (4 classification errors vs one). Probably due to the fact that the golf dataset is very small.
Thanks for the fast response!
