Failed to connect to [tcp://127.0.0.1:5672] or 404 error
ABIM
Hello
How can I solve this error in server?
"failed to connect to [tcp://127.0.0.1:5672]" or "404 error" while running server.
Regards
A
BalazsBaranyRM
is this a docker-container deployment or a direct installation?
Port 5672 is the included ActiveMQ message broker system. In a Docker based deployment it is provided by the rm-server-svc container; with the direct installation the Server should start it automatically.
Please try to look into the logs and search for activemq-related error messages there.
Balázs
ABIM
@BalazsBarany
Hello
Thank you for your answer. Just I installed AI hub. If docker has any setup please let me know how to install and use it.
Best regards
A
BalazsBaranyRM
here's the information on the Docker-based deployment:
https://docs.rapidminer.com/9.8/deployment/overview/
Also a video series on Academy:
https://academy.rapidminer.com/catalog?query=docker deployment
It's an alternative setup method for complex AI Hub deployments including Jupyter Notebooks, Dashboards and more.
If you just want to execute some web services and already installed AI Hub with the installer, that's fine.
Please check the logs for errors to determine the reason for your problems.
Balázs
ABIM
@BalazsBarany
unfortunately AI hub doesn't work.
I spent some days to fix AI hub but I couldn't.
Now I don't know what should I do .
Regards
A
JamilAhmed
@BalazsBarany
Hi, I have deployed AI Hub 9.8 on the Docker-based deployment, now I want to upgrade it to the 9.10 version is there any document there for upgrading, or if you have done it then can you please describe the steps to be followed? Thank you
BalazsBaranyRM
Hi!
Upgrade documentation for 9.9:
https://docs.rapidminer.com/9.9/deployment/manage/upgrade.html
For 9.10:
https://docs.rapidminer.com/latest/deployment/manage/upgrade.html
Best regards,
Balázs
