Attributes do not match
Nawaf
Hello, I wanted to create multi-label classifier with 13 labels and I successfully did the training and testing phases. But the problem when I loaded the model, as shown in below image, there was an error message that attributes do not match.
I attached the model development as well to make sure all good.
Thanks in advance!
lionelderkrikor
@Nawaf
You can find in attached file a "training process" which gives a special role to all attributes you want to predict (with a
Loop attributes
operator).
Please run this "training" process first and then run your "Prediction.rmp" process. In my case, this last process is working fine.
Hope this helps,
Lionel
Text_processing_training.rmp
Telcontar120
Probably you have not done the same exact preprocessing ETL in the model development set as in the new data you are trying to apply the model to. You need to make sure you do all the same transformations, etc., otherwise your model may be trying to use attributes that don't exist or have been modified from their raw form.
Nawaf
I did all the exact preprocessing for both
Telcontar120
Well, somehow RapidMiner determines that the attributes are not the same, since that is what the error is telling you. You should do a row by row comparison of the attributes in both files and double check things like attribute names and data types (sometimes a data type will come in one file as numeric and another file as polynominal, or other similar problems).
Nawaf
I will explain how I did it to ensure I'm on the right road. All labels were sat as binomial before importing them. Then I use multi label classification binary relevance (0, 1) in training phase. In application phase, I provide only the texts alongside labels to let machine predict (0 or 1) for each label. As I said I follow the exact preprocessing
lionelderkrikor
Hi
@Nawaf
In order we can reproduce what you observe and thus understand what is going on, can you please share your process and data ?
Lionel
Nawaf
This is a sample of the trained data
This is its main and inner process
This is a sample of data need to be predicted
Hopefully you could help me to discover the error
lionelderkrikor
@Nawaf
To be honest, the pictures you shared are too small to be read, thus these pictures are unusable :
Can you please share :
- your RM process (.rmp file) via
File
E
xport Process
your different data files (a priori Excel files)
Thank you for your understanding,
Lionel
Nawaf
Nawaf
sorry for the confusion, how to remove unrelated file from previous post
lionelderkrikor
click on the wheel of your psot and click on "Edit" and delete what you want to delete
Lionel :
PS : I'm working on your process, I think that you did not connect the wordlist got from your training process (that you Store) to the
word input port of your
Process documents from data
of your "prediction process".
This way the word attributes are strictly the same in your "training process" and in your "prediction process" which is a mandatory condition for your "prediction process" to work as explained by
@Telcontar120
Nawaf
It doesn't allow me to delete attachments
So wordlist is the problem?
lionelderkrikor
@Nawaf
Please try this "prediction process" (in attached file) with your real data.
You will see that I connected the wordlist that you store in your "training process" to the wordlist input port of your
Process Documents from Data
Please try it and tell me if the prediction process is working fine now ….
Lionel
PS : Note that this process will still raise an error because you have only missing values on your testing excel file...
Text_processing_prediction.rmp
Nawaf
Thanks a lot!
Is this model for training or unseen data prediction?
lionelderkrikor
@Nawaf
The model I shared is for unseen data prediction (to be executed AFTER execution of the training process)
Lionel
Nawaf
Why you put multi-label modeling operators again since I already stored it in training phases
Nawaf
I'm not sure if you check both models I did. One for training that worlist and model stored and other one for prediction loaded the stored worlist and model. I attached them
Nawaf
These
Nawaf
lionelderkrikor
Sorry for the confusion but if you check both files, you can see I divided this model into two phases and did the wordlist connection in prediction file
lionelderkrikor
@Nawaf
I think I understood: it is linked to the fact that you did not give a "special role" to the attributes you want to predict (the labels) :
To be sure to understand you want to predict all your attributes (surveillance, compulsion etc. ) based on your "Text" attribute" ,right ?
Lionel
Nawaf
@lionelderkrikor
I did but gave the same error
lionelderkrikor
@Nawaf
Loop attributes
operator).
Hope this helps,
Lionel
Nawaf
You are the best, it finally works.
