Maximum size of a cell using Documents to Data?
Hi there,
is there a maximum size for a cell when first reading a pdf-file (via Read Document) and then storing it in an example set via Documents to Data?
If I only use Read Document, the full text is returned as output.
If I use Read Document and Documents to data, only a part of the text is stored in the example set
1 - 4 of
41
kayman
New Altair Community Member
Accepted Answer
The cell preview is truncated, so you may be mislead in this case. Could you try to just copy the cell content and paste it in a text file? This way you can validate if you see all content or not.
1 - 2 of
21
