when trying to write an exampleset to a repository, the following error occurs:
- Exception: java.security.AccessControlException
- Message: access denied ("java.io.FilePermission" "C:\Users\wolfr\Documents\RapidMiner\Repositories\Test\Test.rmhdf5table" "write")
- Stack trace:
- java.security.AccessControlContext.checkPermission(AccessControlContext.java:472)
- java.security.AccessController.checkPermission(AccessController.java:886)
- java.lang.SecurityManager.checkPermission(SecurityManager.java:549)
- com.rapidminer.security.PluginSecurityManager.checkPermission(PluginSecurityManager.java:42)
- java.lang.SecurityManager.checkWrite(SecurityManager.java:979)
- java.io.FileOutputStream.(FileOutputStream.java:200)
- org.apache.commons.io.FileUtils.openOutputStream(FileUtils.java:365)
- org.apache.commons.io.FileUtils.openOutputStream(FileUtils.java:324)
- org.apache.commons.io.FileUtils.touch(FileUtils.java:440)
- com.rapidminer.versioning.repository.FileSystemRepository.createFile(FileSystemRepository.java:282)
- com.rapidminer.versioning.repository.FileSystemRepository.createFile(FileSystemRepository.java:61)
- com.rapidminer.versioning.repository.RepositoryFolder.createFile(RepositoryFolder.java:167)
- com.rapidminer.repository.versioned.BasicFolder.createIOObjectEntry(BasicFolder.java:208)
- com.rapidminer.repository.versioned.FilesystemRepositoryAdapter.createIOObjectEntry(FilesystemRepositoryAdapter.java:251)
- com.rapidminer.repository.RepositoryManager.store(RepositoryManager.java:651)
- com.rapidminer.repository.RepositoryManager.store(RepositoryManager.java:626)
- com.rapidminer.Process.saveResults(Process.java:1181)
- com.rapidminer.Process.executeRoot(Process.java:1467)
- com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1443)
- com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:362)
- java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
- java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
- java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
- java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:175)
I am using RM Studio 9.8
Thanks
Wolfram
