How to trigger a process in rapid miner studio without the help of rapid miner AI hub (server)
Karthick
I'm very new to rapid miner, trying out this way !
Triggering ( when a data is change in the table or passing the dataset / data ) a process in Rapid Miner Studio is it possible ?
If it is possible let know how ?
Automation
.RapidMiner
CRON Triggers + Scheduling
Karthick
Triggering ( when a data is change in the table or passing the dataset / data ) a process in Rapid Miner Studio is it possible without the help of rapid miner AI Hub(Server) ?
BalazsBaranyRM
Hi!
This is a very interesting problem. The solution depends on your data. You either need a mechanism to notify the process of the change, or poll for data changes.
Polling is the simplest method. If you can run Studio all the time and set up a process with a Loop and a Delay operator, you can check the changed condition there (e. g. with Branch) and execute a second process in this case.
If you have a method of getting notified of the event and launching a command line program, check out the rapidminer-batch launcher in the
scripts
folder of your Studio installation. This executes a process without launching the graphical user interface. Of course, if the event happens quite often and the startup time of Studio is too long for this, polling might still be a better option.
Balázs
