<?xml version="1.0" encoding="UTF-8"?><process version="9.7.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.7.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value="yhuang@rapidminer.com"/> <parameter key="process_duration_for_mail" value="1"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.7.002" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Titanic Training"/> </operator> <operator activated="true" class="sort" compatibility="9.7.002" expanded="true" height="82" name="Sort" width="90" x="179" y="34"> <parameter key="attribute_name" value="Passenger Fare"/> <parameter key="sorting_direction" value="decreasing"/> </operator> <operator activated="true" class="generate_id" compatibility="9.7.002" expanded="true" height="82" name="Generate ID" width="90" x="313" y="34"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.7.002" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="34"> <list key="function_descriptions"> <parameter key="Top_10percentile" value="if(id<92,"Top10","Other")"/> </list> <parameter key="keep_all" value="true"/> <description align="center" color="transparent" colored="false" width="126">top10 percentile fare or others</description> </operator> <connect from_op="Retrieve Titanic Training" from_port="output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
