Dear RapidMiner community,
I try to save a chart to a file in a following way:
1. I don't want the chart title to be visible
2. I want to make labels of the Y axis larger, and I set the font size to 20 or greater: Y-Axis -> Axis style -> Labels style -> Label font
The "0.72" number is now not completely visible (see attached file).
Right now I do the following as a work around: I make the "Title" visible and set the font color to white, but I have a feeling it should be just working.
And here is the code:
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.7.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.7.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="136">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="id,value 1,0.7034 2,0.6502 3,0.6212 4,0.5734 5,0.5553"/>
<parameter key="column_separator" value=","/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<connect from_op="Create ExampleSet" from_port="output" to_port="result 1"/>
</process>
</process>
Do you think there is any other option of making it work? I generate a lot of charts and I have a lot of an additional work to do because of that.
Best regards
Maciek
