This is my Example Set
The tutorial for this Optimize Parameters describes edit_parameter_settings.
The parameters are selected through the edit parameter settings menu. You can select the parameters and their possible values through this menu. This menu has an Operators window which lists all the operators in the subprocess of this Operator.
When I go to Parameters and click on Edit Parameter Settings,
I get the subprocess without options, no links at all.
Any helpful suggestions would be greatly appreciated.
Tony
