#!/bin/bash -l #################################### # slurm script template # # # # Submit script: sbatch filename # # # #################################### #SBATCH --job-name=rapidminer # Job name #SBATCH --output=rapidminer.%j.out # Stdout (%j expands to jobId) #SBATCH --error=rapidminer.%j.err # Stderr (%j expands to jobId) #SBATCH --ntasks=3 # Number of tasks(processes) #SBATCH --nodes=1 # Number of nodes requested #SBATCH --ntasks-per-node=3 # Tasks per node #SBATCH --cpus-per-task=1 # Threads per task #SBATCH --time=10:10:30 # walltime #SBATCH --mem=64G # memory per NODE #SBATCH --partition=task # Partition #SBATCH --account=pa # Replace with your system project if [ x$SLURM_CPUS_PER_TASK == x ]; then export OMP_NUM_THREADS=1 else export OMP_NUM_THREADS=$SLURM_CPUS_PER_TASK fi ## LOAD MODULES ## module purge # clean up loaded modules # load necessary modules module load gnu/4.9.2 module load intel/15.0.3 module load intelmpi/5.0.3 module load cuda/8.0.61 module load java/1.8.0 module load python/3.5.0 ## RUN YOUR PROGRAM ## srun ./rapidminer-studio/scripts/rapidminer-batch.sh -f /rapidminercodes/xml.rmp
