Using Charts/Visualizations and
Hi, I have an assignment for a class using rapid miner. I think the professor gave us outdated instructions and rapid miner has since updated. Do you know where I would find "Charts" and "Series Multiple" after I stored two different datasets? The instructions say this specifically: Let’s compare data set 1 with data set 2 over time. In the Results view, go to the Charts tab, and under Chart style at the top of the tab, choose Series Multiple, which allows you to compare trends between multiple series. Under Plot Series choose two corresponding series from the data set 1 and the data set 2. Have the two series moved in similar directions over time, or not?
