Verify that Python 3.8 is installed and working correctly on your system.
Check Anaconda if you're using it and ensure the correct environment is active.
Add the path to your Python installation directory to your system's PATH variable.
Check and configure the Python interpreter in RapidMiner's settings.
Restart RapidMiner after making changes.
Test by running a simple Python script in RapidMiner. If issues persist, provide more details for further help.
