Spreadsheet, table with attribute weights of each model in Auto Model
DocMusher
I am wondering if there is a way to create a table consisting of the attribute weights provided by each model used in Auto Model (Different from weight by correlation, rather weight by algorithm)
This would provide an additional way to select the model of preference to deploy (together with resiliency and time needed to compute)
Thanks
Sven
Weights
Auto Model
MartinLiebig
Hi
@DocMusher
we can store the resuts of auto model and create a quick process which gets you all the weights in an ExampleSet to export it. Would this work?
Best,
Martin
MartinLiebig
Hi
@DocMusher
here you are. Process Attached.
Cheers,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.7.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="loop_repository" compatibility="9.7.001" expanded="true" height="82" name="Loop Repository" width="90" x="45" y="34">
<parameter key="repository_folder" value="//Local Repository/Forum/Sven AM"/>
<parameter key="entry_type" value="IOObject"/>
<parameter key="filter" value="Weights"/>
<parameter key="filtered_string" value="file name (last part of the path)"/>
<parameter key="entry_name_macro" value="entry_name"/>
<parameter key="repository_path_macro" value="repository_path"/>
<parameter key="parent_folder_macro" value="parent_folder"/>
<parameter key="recursive" value="true"/>
<operator activated="true" class="handle_exception" compatibility="9.7.001" expanded="true" height="82" name="Handle Exception" width="90" x="112" y="34">
<parameter key="add_details_to_log" value="false"/>
<operator activated="true" class="weights_to_data" compatibility="9.7.001" expanded="true" height="68" name="Weights to Data" width="90" x="45" y="34"/>
<operator activated="true" class="generate_attributes" compatibility="9.7.001" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34">
<parameter key="model" value="%{parent_folder}"/>
</list>
<parameter key="keep_all" value="true"/>
<connect from_port="in 1" to_op="Weights to Data" to_port="attribute weights"/>
<connect from_op="Weights to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
</process>
<connect from_port="repository object" to_op="Handle Exception" to_port="in 1"/>
<connect from_op="Handle Exception" from_port="out 1" to_port="out 1"/>
<portSpacing port="source_repository object" spacing="0"/>
</process>
<description align="center" color="transparent" colored="false" width="126">Choose the AM Results folder here!</description>
<operator activated="true" class="operator_toolbox:advanced_append" compatibility="2.6.000" expanded="true" height="82" name="Append (Superset)" width="90" x="179" y="34"/>
<operator activated="true" class="blending:pivot" compatibility="9.7.001" expanded="true" height="82" name="Pivot" origin="GENERATED_TURBOPREP" width="90" x="380" y="34">
<parameter key="group_by_attributes" value="Attribute"/>
<parameter key="column_grouping_attribute" value="model"/>
<parameter key="Weight" value="average"/>
</list>
<parameter key="use_default_aggregation" value="false"/>
<parameter key="default_aggregation_function" value="first"/>
<operator activated="true" class="rename_by_replacing" compatibility="9.7.001" expanded="true" height="82" name="Rename by Replacing" width="90" x="581" y="34">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="replace_what" value="average\((.+)\)"/>
<parameter key="replace_by" value="$1"/>
<connect from_op="Loop Repository" from_port="out 1" to_op="Append (Superset)" to_port="example set 1"/>
<connect from_op="Append (Superset)" from_port="merged set" to_op="Pivot" to_port="input"/>
<connect from_op="Pivot" from_port="output" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/>
</process>
</process>
MartinLiebig
Hi
@DocMusher
Best,
Martin
DocMusher
Yes, this would be a good solution!
MartinLiebig
Hi
@DocMusher
Cheers,
Martin
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</process>
</process>
</process>
</list>
</process>
</process>
DocMusher
Great!!!!!! Thanks
