the goal is to apply several models for/within the multi label modeling operator. Therefore I use the Loop Parameters Operator within the Multi Label Modeling Operator. However it doesnt work. Below is the process with the titanic data set. Does anyone have another suggestion? Thanks!
<process version="9.7.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.7.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.7.000" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Samples/data/Titanic Training"/>
<operator activated="true" class="set_role" compatibility="9.7.000" expanded="true" height="82" name="Set Role" width="90" x="179" y="34">
<parameter key="attribute_name" value="Survived"/>
<parameter key="target_role" value="Survived"/>
<list key="set_additional_roles">
<parameter key="Passenger Class" value="Passenger Class"/>
</list>
<operator activated="true" class="time_series:multi_label_model_learner" compatibility="9.7.000" expanded="true" height="103" name="Multi Label Modeling" width="90" x="313" y="34">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="Survived|Passenger Class"/>
<parameter key="add_macros" value="false"/>
<parameter key="current_label_name_macro" value="current_label_attribute"/>
<parameter key="current_label_type_macro" value="current_label_type"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="concurrency:loop_parameters" compatibility="9.7.000" expanded="true" height="103" name="Loop Parameters" width="90" x="313" y="34">
<list key="parameters">
<parameter key="Select Subprocess.select_which" value="[1.0;2;2;linear]"/>
</list>
<parameter key="error_handling" value="fail on error"/>
<parameter key="log_performance" value="true"/>
<parameter key="log_all_criteria" value="false"/>
<parameter key="synchronize" value="false"/>
<operator activated="true" class="select_subprocess" compatibility="9.7.000" expanded="true" height="103" name="Select Subprocess" width="90" x="313" y="34">
<parameter key="select_which" value="1"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.7.000" expanded="true" height="145" name="Cross Validation" width="90" x="179" y="34">
<parameter key="split_on_batch_attribute" value="false"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_folds" value="10"/>
<parameter key="sampling_type" value="automatic"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<operator activated="true" class="concurrency:parallel_random_forest" compatibility="9.7.000" expanded="true" height="103" name="Random Forest" width="90" x="112" y="34">
<parameter key="number_of_trees" value="100"/>
<parameter key="criterion" value="gain_ratio"/>
<parameter key="maximal_depth" value="10"/>
<parameter key="apply_pruning" value="false"/>
<parameter key="confidence" value="0.1"/>
<parameter key="apply_prepruning" value="false"/>
<parameter key="minimal_gain" value="0.01"/>
<parameter key="minimal_leaf_size" value="2"/>
<parameter key="minimal_size_for_split" value="4"/>
<parameter key="number_of_prepruning_alternatives" value="3"/>
<parameter key="random_splits" value="false"/>
<parameter key="guess_subset_ratio" value="true"/>
<parameter key="subset_ratio" value="0.2"/>
<parameter key="voting_strategy" value="confidence vote"/>
<connect from_port="training set" to_op="Random Forest" to_port="training set"/>
<connect from_op="Random Forest" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.7.000" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
<parameter key="create_view" value="false"/>
<operator activated="true" class="performance_classification" compatibility="9.7.000" expanded="true" height="82" name="Performance" width="90" x="246" y="34">
<parameter key="main_criterion" value="first"/>
<parameter key="accuracy" value="true"/>
<parameter key="classification_error" value="false"/>
<parameter key="kappa" value="false"/>
<parameter key="weighted_mean_recall" value="false"/>
<parameter key="weighted_mean_precision" value="false"/>
<parameter key="spearman_rho" value="false"/>
<parameter key="kendall_tau" value="false"/>
<parameter key="absolute_error" value="false"/>
<parameter key="relative_error" value="false"/>
<parameter key="relative_error_lenient" value="false"/>
<parameter key="relative_error_strict" value="false"/>
<parameter key="normalized_absolute_error" value="false"/>
<parameter key="root_mean_squared_error" value="false"/>
<parameter key="root_relative_squared_error" value="false"/>
<parameter key="squared_error" value="false"/>
<parameter key="correlation" value="false"/>
<parameter key="squared_correlation" value="false"/>
<parameter key="cross-entropy" value="false"/>
<parameter key="margin" value="false"/>
<parameter key="soft_margin_loss" value="false"/>
<parameter key="logistic_loss" value="false"/>
<parameter key="skip_undefined_labels" value="true"/>
<parameter key="use_example_weights" value="true"/>
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Cross Validation" to_port="example set"/>
<connect from_op="Cross Validation" from_port="model" to_port="output 1"/>
<connect from_op="Cross Validation" from_port="performance 1" to_port="output 2"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
</process>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.7.000" expanded="true" height="145" name="Cross Validation (2)" width="90" x="179" y="34">
<operator activated="true" class="naive_bayes" compatibility="9.7.000" expanded="true" height="82" name="Naive Bayes" width="90" x="112" y="34">
<parameter key="laplace_correction" value="true"/>
<connect from_port="training set" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.7.000" expanded="true" height="82" name="Apply Model (2)" width="90" x="112" y="34">
<operator activated="true" class="performance_classification" compatibility="9.7.000" expanded="true" height="82" name="Performance (2)" width="90" x="246" y="34">
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Performance (2)" from_port="performance" to_port="performance 1"/>
</process>
<connect from_port="input 1" to_op="Cross Validation (2)" to_port="example set"/>
<connect from_op="Cross Validation (2)" from_port="model" to_port="output 1"/>
<connect from_op="Cross Validation (2)" from_port="performance 1" to_port="output 2"/>
</process>
<connect from_port="input 1" to_op="Select Subprocess" to_port="input 1"/>
<connect from_op="Select Subprocess" from_port="output 1" to_port="output 1"/>
<connect from_op="Select Subprocess" from_port="output 2" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<connect from_port="training set" to_op="Loop Parameters" to_port="input 1"/>
<connect from_op="Loop Parameters" from_port="output 1" to_port="model"/>
<connect from_op="Loop Parameters" from_port="output 2" to_port="output 1"/>
</process>
<connect from_op="Retrieve Titanic Training" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Multi Label Modeling" to_port="training set"/>
<connect from_op="Multi Label Modeling" from_port="model" to_port="result 1"/>
<connect from_op="Multi Label Modeling" from_port="output 1" to_port="result 2"/>
</process>
</process>
