<?xml version="1.0" encoding="UTF-8"?><process version="9.7.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.7.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.7.001" expanded="true" height="68" name="Retrieve Sonar" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.7.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="179" y="136"> <list key="function_descriptions"> <parameter key="min_1" value="MISSING_NUMERIC"/> <parameter key="min_2" value="MISSING_NUMERIC"/> <parameter key="min_3" value="MISSING_NUMERIC"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="extract_macro" compatibility="9.7.001" expanded="true" height="68" name="Extract Macro" width="90" x="313" y="136"> <parameter key="macro" value="total_rows"/> <parameter key="macro_type" value="number_of_examples"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value=""/> <list key="additional_macros"/> </operator> <operator activated="true" class="concurrency:loop" compatibility="9.7.001" expanded="true" height="82" name="Loop" width="90" x="447" y="136"> <parameter key="number_of_iterations" value="%{total_rows}"/> <parameter key="iteration_macro" value="i"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="9.7.001" expanded="true" height="82" name="Filter Example Range" width="90" x="112" y="85"> <parameter key="first_example" value="%{i}"/> <parameter key="last_example" value="%{i}"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="multiply" compatibility="9.7.001" expanded="true" height="103" name="Multiply" width="90" x="246" y="85"/> <operator activated="true" class="transpose" compatibility="9.7.001" expanded="true" height="82" name="Transpose" width="90" x="380" y="340"/> <operator activated="true" class="sort" compatibility="9.7.001" expanded="true" height="82" name="Sort" width="90" x="514" y="340"> <parameter key="attribute_name" value="att_1"/> <parameter key="sorting_direction" value="increasing"/> </operator> <operator activated="true" class="operator_toolbox:extract_macro_enhanced" compatibility="2.6.000" expanded="true" height="68" name="Extract Macro (Format)" width="90" x="648" y="340"> <parameter key="macro" value="min_1"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="att_1"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> <parameter key="format_of_numericals" value="#.##"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> </operator> <operator activated="true" class="operator_toolbox:extract_macro_enhanced" compatibility="2.6.000" expanded="true" height="68" name="Extract Macro (Format) (2)" width="90" x="782" y="340"> <parameter key="macro" value="min_2"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="att_1"/> <parameter key="example_index" value="2"/> <list key="additional_macros"/> <parameter key="format_of_numericals" value="#.##"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> </operator> <operator activated="true" class="operator_toolbox:extract_macro_enhanced" compatibility="2.6.000" expanded="true" height="68" name="Extract Macro (Format) (3)" width="90" x="916" y="340"> <parameter key="macro" value="min_3"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="att_1"/> <parameter key="example_index" value="3"/> <list key="additional_macros"/> <parameter key="format_of_numericals" value="#.##"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.7.001" expanded="true" height="82" name="Generate Attributes (3)" width="90" x="447" y="85"> <list key="function_descriptions"> <parameter key="min_1" value="eval(%{min_1})"/> <parameter key="min_2" value="eval(%{min_2})"/> <parameter key="min_3" value="eval(%{min_3})"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_port="input 1" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Transpose" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Generate Attributes (3)" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Extract Macro (Format)" to_port="example set"/> <connect from_op="Extract Macro (Format)" from_port="example set" to_op="Extract Macro (Format) (2)" to_port="example set"/> <connect from_op="Extract Macro (Format) (2)" from_port="example set" to_op="Extract Macro (Format) (3)" to_port="example set"/> <connect from_op="Generate Attributes (3)" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="9.7.001" expanded="true" height="82" name="Append" width="90" x="581" y="136"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.7.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="generate_id" compatibility="9.7.000" expanded="true" height="82" name="Generate ID (117)" width="90" x="313" y="187"> <parameter key="create_nominal_ids" value="true"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="multiply" compatibility="9.7.000" expanded="true" height="82" name="Multiply (20)" width="90" x="447" y="187"/> <operator activated="true" class="transpose" compatibility="9.7.000" expanded="true" height="82" name="Transpose (82)" width="90" x="581" y="187"/> <operator activated="true" class="concurrency:loop_attributes" compatibility="9.7.000" expanded="true" height="82" name="Loop Attributes (5)" width="90" x="715" y="187"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="attribute_name_macro" value="loop_attribute"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="select_attributes" compatibility="9.7.000" expanded="true" height="82" name="Select Attributes (153)" width="90" x="45" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{loop_attribute}"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="operator_toolbox:extract_macro_enhanced" compatibility="2.6.000" expanded="true" height="68" name="Extract Macro (Format) (3)" width="90" x="179" y="34"> <parameter key="macro" value="center"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="%{loop_attribute}"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> <parameter key="format_of_numericals" value="#.##"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> </operator> <operator activated="true" class="sort" compatibility="9.7.000" expanded="true" height="82" name="Sort (2)" width="90" x="313" y="34"> <parameter key="attribute_name" value="%{loop_attribute}"/> <parameter key="sorting_direction" value="increasing"/> </operator> <operator activated="true" class="generate_id" compatibility="9.7.000" expanded="true" height="82" name="Generate ID (119)" width="90" x="447" y="34"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <connect from_port="input 1" to_op="Select Attributes (153)" to_port="example set input"/> <connect from_op="Select Attributes (153)" from_port="example set output" to_op="Extract Macro (Format) (3)" to_port="example set"/> <connect from_op="Extract Macro (Format) (3)" from_port="example set" to_op="Sort (2)" to_port="example set input"/> <connect from_op="Sort (2)" from_port="example set output" to_op="Generate ID (119)" to_port="example set input"/> <connect from_op="Generate ID (119)" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_collection" compatibility="9.7.000" expanded="true" height="68" name="Loop Collection (3)" width="90" x="849" y="187"> <parameter key="set_iteration_macro" value="true"/> <parameter key="macro_name" value="iteration"/> <parameter key="macro_start_value" value="1"/> <parameter key="unfold" value="false"/> <process expanded="true"> <operator activated="true" class="branch" compatibility="9.7.000" expanded="true" height="82" name="Branch (7)" width="90" x="45" y="34"> <parameter key="condition_type" value="expression"/> <parameter key="expression" value="%{iteration}==1"/> <parameter key="io_object" value="ANOVAMatrix"/> <parameter key="return_inner_output" value="true"/> <process expanded="true"> <operator activated="true" class="remember" compatibility="9.7.000" expanded="true" height="68" name="Remember (2)" width="90" x="45" y="34"> <parameter key="name" value="dataset"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="store_which" value="1"/> <parameter key="remove_from_process" value="true"/> </operator> <connect from_port="condition" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="recall" compatibility="9.7.000" expanded="true" height="68" name="Recall (5)" width="90" x="45" y="34"> <parameter key="name" value="dataset"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="true"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.7.000" expanded="true" height="82" name="Join (96)" width="90" x="179" y="85"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="left"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"/> <parameter key="keep_both_join_attributes" value="false"/> </operator> <operator activated="true" class="remember" compatibility="9.7.000" expanded="true" height="68" name="Remember (6)" width="90" x="313" y="85"> <parameter key="name" value="dataset"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="store_which" value="1"/> <parameter key="remove_from_process" value="true"/> </operator> <connect from_port="condition" to_op="Join (96)" to_port="right"/> <connect from_op="Recall (5)" from_port="result" to_op="Join (96)" to_port="left"/> <connect from_op="Join (96)" from_port="join" to_op="Remember (6)" to_port="store"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> </process> </operator> <connect from_port="single" to_op="Branch (7)" to_port="condition"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <operator activated="true" class="recall" compatibility="9.7.000" expanded="true" height="68" name="Recall (6)" width="90" x="179" y="289"> <parameter key="name" value="dataset"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="true"/> </operator> <operator activated="true" class="generate_id" compatibility="9.7.000" expanded="true" height="82" name="Generate ID (118)" width="90" x="313" y="289"> <parameter key="create_nominal_ids" value="true"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="transpose" compatibility="9.7.000" expanded="true" height="82" name="Transpose (83)" width="90" x="447" y="289"/> <operator activated="true" class="select_attributes" compatibility="9.7.000" expanded="true" height="82" name="Select Attributes (154)" width="90" x="581" y="289"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="id_1|id_2|id_3"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="rename" compatibility="9.7.000" expanded="true" height="82" name="Rename (4)" width="90" x="715" y="289"> <parameter key="old_name" value="id_1"/> <parameter key="new_name" value="distance1"/> <list key="rename_additional_attributes"> <parameter key="id_2" value="distance2"/> <parameter key="id_3" value="distance3"/> </list> </operator> <operator activated="true" breakpoints="after" class="concurrency:join" compatibility="9.7.000" expanded="true" height="82" name="Join (42)" width="90" x="849" y="289"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"/> <parameter key="keep_both_join_attributes" value="false"/> </operator> <connect from_op="Generate ID (117)" from_port="example set output" to_op="Multiply (20)" to_port="input"/> <connect from_op="Multiply (20)" from_port="output 1" to_op="Transpose (82)" to_port="example set input"/> <connect from_op="Transpose (82)" from_port="example set output" to_op="Loop Attributes (5)" to_port="input 1"/> <connect from_op="Transpose (82)" from_port="original" to_op="Join (42)" to_port="left"/> <connect from_op="Loop Attributes (5)" from_port="output 1" to_op="Loop Collection (3)" to_port="collection"/> <connect from_op="Recall (6)" from_port="result" to_op="Generate ID (118)" to_port="example set input"/> <connect from_op="Generate ID (118)" from_port="example set output" to_op="Transpose (83)" to_port="example set input"/> <connect from_op="Transpose (83)" from_port="example set output" to_op="Select Attributes (154)" to_port="example set input"/> <connect from_op="Select Attributes (154)" from_port="example set output" to_op="Rename (4)" to_port="example set input"/> <connect from_op="Rename (4)" from_port="example set output" to_op="Join (42)" to_port="right"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
